George Chronis
All good. Just wanted to make sure anyone who was potentially trying to buy it had the right info...Hey bro. Yes, the two switches for Hi/Lo Z and Hi/Lo Power are missing. Got a lesson in WA5s today.
I had a WA5-LE so thought the WA5 had the same design life. Looks like the WA5-LE V2s design was taken from the OG WA5. Interesting.All good. Just wanted to make sure anyone who was potentially trying to buy it had the right info...
Correct. The LE v2 also has (almost) the same power to the headphone outs that the OG WA5 had to the speaker or the K1K out. I'm sure that has something to do with it I also have the OG WA5-LE. I've been debating on switching it for a gen 2, but decided against it... I love this amp!I had a WA5-LE so thought the WA5 had the same design life. Looks like the WA5-LE V2s design was taken from the OG WA5. Interesting.
Yup. It takes serious willpower to tear yourself loose.The WA2 arrived today. I honestly can’t believe how much I like it. I love the WA22, but holy smokes, this thing is impossible to turn off …
Congratulations and welcome to the WA2 Club!I guess this thing is just magic. If you guys are saying it’s only going to get better with better drivers, I’m almost afraid, but very excited!
Those should be fine for cleaning. I got their vacuum tube kit - it’s the DeoxIt Gold GX-MD with that one. I think it’s rated for high temp and you can keep a very thin coat on your tube pins / sockets to lubricate and seal them. I’ve also been using a handheld Dremel Lite with the D100L and some of the Dremel polishing compound and a compressed felt polishing head to take the grime off of the pins on NOS tubes. It might just be in my head, but I definitely think it helps the sound when you have old tubes with cruddy pins.Hey! quick question. Do you guys know if any of these 2 contact cleaners will work with tubes?
https://a.co/d/4azmpkT
https://a.co/d/hkUEzU7
One of my 300Bs has developed a noise that is correct by cleaning the pins with a dry cloth every time I want to power on my WA5. But I'm afraid that I'm wearing out the tube socket little by little by doing this.
I think you are refering to this one, https://a.co/d/fRc1CRH.Those should be fine for cleaning. I got their vacuum tube kit - it’s the DeoxIt Gold GX-MD with that one. I think it’s rated for high temp and you can keep a very thin coat on your tube pins / sockets to lubricate and seal them. I’ve also been using a handheld Dremel Lite with the D100L and some of the Dremel polishing compound and a compressed felt polishing head to take the grime off of the pins on NOS tubes. It might just be in my head, but I definitely think it helps the sound when you have old tubes with cruddy pins.
Even the stock tubes with my WA2 were filthy. Amazing how much they cleaned up, and I think it wasn’t a night and day improvement in sound, but it seemed to improve resolution a tiny bit.
Actually, this is the one -I think you are refering to this one, https://a.co/d/fRc1CRH.
Apologies for missing this until now, @Promee . Great to hear the new tubes are serving you well, and that my input was helpful!New tube day!!!!!
@AudioDuck - Just as expected, the Siemens, which I believe is similar to Amperex, are extremely clear, balanced, maybe a tiny bit bright, but they seem lovely - I definitely haven’t broken them in because I have been listening for the past couple of hours to the Mullard / RTC 7308 pair, and they are just as you said, warm, somewhat bass boosted, but not lacking for detail when you look, just not overly etched. They’re making my HD 600 sound like they have the bass of the 6XX, but then these little details will pop up just to surprise and delight The Mullards will be getting the burn-in treatment first. They are both much more clear / detailed than the stock tubes. It never fails to stun me in this hobby how you just don’t know what you’re missing, right up until you do… So, @AudioDuck - fantastic recommendation!
Are those different from the RFT EZ81 that is stock on the WA2 now? Reading a little about these, I wonder if getting Woo’s GE EZ80 upgrade rectifier without researching was a mistake…Apologies for missing this until now, @Promee . Great to hear the new tubes are serving you well, and that my input was helpful!
I’ve been listening to my WA2 pretty extensively with my Verité Closed and Atrium Closed this weekend with a range of music. I continue to marvel at what the WA2 can do, held up against a $3,000 solid-state amp (my Apache)…
In general I prefer the WA2 (with RFT EZ81 foil-getter rectifiers, Tung-Sol 5998 power tubes, and Telefunken G73-R input tubes- and, yes, a fuse upgrade to a Synergistic Research Purple) by a fair margin.
That’s not to say anything negative about The Apache at all… But it puts the WA2’s performance ceiling in perspective. (And yes, I know those are some expensive tubes, but tubes are variable in price!)
I don’t honestly know, but I’d say if you’re happy with the sound you’re getting, I wouldn’t worry about it. Funnily enough, rectifier tubes have been “set and forget” for me once I got the RFTs.Are those different from the RFT EZ81 that is stock on the WA2 now? Reading a little about these, I wonder if getting Woo’s GE EZ80 upgrade rectifier without researching was a mistake…
I’ve actually never blown a fuse on any of my gear, so it hasn’t been a concern to me. All I can say is that to me, there was a significant and very audible difference with the new (SR Purple) fuse in place.It’s one of those things where I don’t know what I don’t know about the fuses, but I have blown so many fuses over time that I would lose it if I blew a several hundred dollar one…
