Maybe you can try to look for an building fitter that is specialized in shaping of sheet. Maybe they can custom build some kind of mesh plate or perforated metal plate or some kind of metal cage?
I thought I’d show my setup. We moved to a new house last year with a bit more space, so I was able to have a stand made for my head-fi setup.
The stand was custom made by Core Audio Designs and features gorgeous flamed maple.
The WA-33 at the top is the Elite edition with the JPS wiring. Original tubes.
DAC is the Chord Hugo TT 2 with the M Scaler.
I typically listen using the Abyss Phi TC (complete version). I’ve had this setup now for nearly two years and adore it. I also occasionally use my Focal Utopias with this setup.
Plenty of room on the stand for other things. Not sure what that would be at the moment . . .
Adequate with the standard WA33, but much better with the WA33 Elite JPS. I have had both versions of the WA33, and I was a tad bit disappointed with the Susvaras out of the standard version. When I got the Elite version, the Susvaras sounded much better. The Susvaras scale up very well.
Adequate with the standard WA33, but much better with the WA33 Elite JPS. I have had both versions of the WA33, and I was a tad bit disappointed with the Susvaras out of the standard version. When I got the Elite version, the Susvaras sounded much better. The Susvaras scale up very well.**
I actually like that they keep scaling up with better equipment. The Susvaras have scaled up better than any of my other headphones. It keeps the chase alive.
