That is gotta be the coolest looking amp I have ever seen. Sounds great just looking at the picture.
And, as a bonus, if you're in a cold climate it invalidates the need for winter heating.
You are correct, 300B’s are good for some sensitive speakers, but that’s limited to some sensitive speakers only, bookshelf speakers at best. No way for them to drive these gigantic tower speakers and subwoofers, even in some push-pull 300B configurations (15-18 watts?).
I personally still think headphone amps is the best place for 300B or 2A3 tubes. If you need large power for these tower speakers, the only feasible choice is solid state amps, but of course you can add some tube pre-amp to get some tubey sound. Or possibly one can spend $$$$$$$$ to get these custom biggies
Using 300B's as pre will be too luxury
I think the best place for 300B is in headphone amps. Because of the limited power/current capacity, I don't think tubes are sufficient to drive speakers (of course those gigantic custom-made tubes are anomalies)
Hi all. I have a used Wa3 arriving soon. I'll be using it primarily with HD6xx's, which sound like should be a great match. I have 2 questions though.
1) It's my first tube amp. If I use it with lower impedance cans like Audeze Lcd-x's will that be a problem or cause damage?
2) If anyone that has tube rolled the Wa3 has any recommendations would love to hear them.
Thanks!
Thanks!
