My experience with a DXe with an Auralic Vega was not a happy one. This is the only big ticket hifi purchase I have made that I totally regret. For some reason the DXe does not want to play nicely with the Vega.
To summarise the issues:
- Software would freeze after every 2 to 3 songs when playing .m4a files.
- Moving to FLAC files fixed the freezing, but when using 'Exact' clock mode on the Vega every song would have a drop out of around 1 second a few seconds into the playback.
- Setting the Vega clock back from 'Exact' to 'Fine' or 'Auto' would give a drop out every 4 or 5 tracks. That is still not acceptable to me. If I pay 3K for a music server it should support the best clock setting my DAC has - this device can't even support the second best clock setting on the Vega. It should also support .m4a files.
I contacted the retailer, who put me in touch with the designer/manufacturer (since we all reside here in NZ). I won't give the details of that exchange unless folks want to hear it - bottom line is that the issues I am having are beyond the user's ability to fix. There are no config settings I can adjust ... etc. The unit arrives with the firmware and software pre-loaded - and it is what it is (mine has the latest firmware loaded).
After all this unsatisfying drama I tried again using my PC (3 year old windows machine) as a server to the Vega. It worked flawlessly, in 'Exact' clock mode, for hours on end, with any file type I threw at it (wav/flac/m4a). Maxing out the buffers on the Vega's windows driver gives a rock solid result. This PC has no special tweaks or hardware or anything else - it is a stock PC running Media Monkey to the Vega via a $5 USB cable.
Keep in mind what a music server is delivering to the DAC - an asynchronous data stream of binary information - not an audio signal. I found my PC did a better job and the sonic result was identical to my ears (apart from the drop outs via the DXe). I also get to chose which the software and file types to use with my PC.
I have purchased an upgraded PC that will become my personal PC, and my 'old' PC will become my music server. The DXe is currently back in it's box gathering dust on my shelf. Not sure what to do with it - I am having trouble selling it in good conscience given the issues I have had.
The DXe might be wonderful with a different DAC - I don't know. For me it was a wasted purchase when paired with the Vega. YMMV.
