solserenade
- Nov 30, 2011
Have you a lamp dimmer nearby? Mine will produce your symptom if the dimmer is in use. Other possible culprit could be a wall-wart making "noise" -- Isolate your rig as much as possible, unplug every thing … then re-plug one at a time, testing for the static. Good luck!Hello Everybody,
I think I have a small grounding issue with my WA6-SE. When I touch the volume knob I can hear static but when I stop touching it no more static. When everything is turned "off" (Source, DAC) I can still hear the static by touching the volume knob... What should I do?
