joyway
- Apr 6, 2013
Thank Lion Tamer for your kind reply. I should start to save money now.(*^__^*)
How did you find 2 matching 596 tubes? I'm lucky if I can score 1, let alone 2, and they never ever match.
Matched what ?
I am the guy that came up with using the 596 in the WA5 what needs to be matched is the filament resistance
during worm up.
There is no commercial equipment made that can measure this I built the tester to do this when I first started
selling adapters and tubes for the WA-5. But people started using the 596 for every thing now they are nearly
unattainable.
The majority of 596 tubes have a close matched filament so almost any pair will be close enough to use in the
WA-5
You're holding out
on me! I didn't know you got a new Woo... WA5 or LE? Wait, more importantly is it Black?
Matched what ?
during worm up.
unattainable.
WA-5
x2, even the stock tubes is a hair better than my wa22 already. once you roll in 596, elm 300b, and ts bgrp. it is on a totally different level. one thing to notice is, it is very demanding amp, it requires the best dac you can afford.
Any of you using the WA6 + HE-5 or HE-5LE? I paired it with the K702 at the meet and it blew my Lyr out of the water entirely! So if it's a good pair for the HiFiMAN's too, I think I'll have to buy a WA6.
might wanna look into the WA6-SE for more power for the hifiman's. mine performs great with HE-500 and was simply sublime with the K701 (8 bump version).
for the AKG's, it'll be the same, just suggested the WA6-SE cause it is better and more importantly would have the power u need if you wanted to go with the hifiman.
the soloist sl would have alot of power, not sure if it would be better than a WA6, especially if you upgrade your tubes.
Well I have the HE-5Le and the Q701, but its most important to work with the HiFiMAN's as they are my prefered can I can't find the power output for 32ohms for the WA6 :/ So I guess I'll have to try it at the meet up in NYC
