If use a same cable geometry, it is the same. Even if you are using TRS, WA22 is not true balanced out even the amp is a balanced amp. It is well documented.
I have a different opinion, on both points. IME, certain headphones respond to balanced cabling, regardless of the amp used.
In regards to the WA22 not being fully balanced, I'm not convinced that is the case either:
[size=medium]The WA22 is a fully balanced amp, see diagram below.[/size]
[size=medium]The question here is that this amp is not fully balanced because the "amp with a single ended output stage directly connected to the XLR connectors.” It is not true. In an Output Transformer coupled design, the primary and secondary coils are isolated. Output stage and input stage are not connected and thus no cross-talk whatsoever can happen.[/size]
[size=medium]On the ¼” output, both channels have independent paths, see the black and red wires. If this wiring scheme applies to a Output Transformer Less design, the circuit will become single-ended. See the second diagram in #17, the v- would have to be a common wire to other channel. One must be carefull not to take reference from the wrong context to avoid all the misunderstanding.[/size]
[size=medium]Also, no phase splitter is needed because the source is XLR (balanced). As for the RCA input, only ½ of the input is used and the efficiency is roughly dropped 50%. In other words, the RCA input will not take advantage of this design. You must use a balanced source to get the best out of the WA22.[/size]
[size=medium]Hope that clarifies.[/size]
[size=medium]-Jack[/size]
From the owner's manual Q&A:
"If I connect the WA22 with RCA interconnects, will the amp still provide a balanced signal to the balanced output?
"No, there is no RCA to Balanced conversion in this amp. A source with a true balanced output will work the best with the WA22."
I understand this as balanced in = balanced out through the balanced outputs, and SE in = SE out through either output. I have also read that the SE/TRS headphone jack sounds just as good as the balanced/XLR jack when using a balanced input, but IME that's not the case. When using the balanced inputs(s), the balanced outputs sound better to me.
