Could someone help refresh my memory about EML 5U4G Mesh failures? I tried the search function but could not find the threads that I thought I remembered.
I have had the same, original EML 5U4G mesh in my WA22 for almost 1 1/2 years now and last night while testing a new pair of Western Electric 421As, I heard a loud pop and saw a flash at start up. I listened for a while and heard/saw no problems. Luckily, no damage to the HD800s.
I then allowed the amp to cool completely. I pulled the 421s out and put some TS 5998s that have been used for many hours. (great tubes!) What I saw this time at start up was a white spark in the EML. I heard no pop because this time the volume was at minimum (note to self...always power up with volume at zero/minimum, which I usually do)
Now, according to the EML site:
If you ignore this design rule, tube damage will result. Also in many "professional" amplifiers, this design rule is not used by designers who do not read the historical data sheets Tube damage can result as a white spark inside the tube at switch on, filament material can chip off, or the tube life will be much reduced. With most amplifiers, the transformer winding is directly connected to the tube socket, and no protective series resistors are used. In most cases, the transformer resistance can be conveniently measured by a specialist, directly at the tube socket, when the rectifier tube is removed first.
The rule referred to above is about resistors. Has this been discussed before, perhaps by Glenn?
