Audiogalore
- Jun 8, 2008
Any of you analog woo'ers use a turntable clamp? Just curious.
Yes!
PanamaRed, I suggest you read a bunch about Rega tables and record clamps. Rega has a different design approach and/or philosophy than (for instance) jerico's VPI Classic player.
You'd think Rega would include a record clamp with at the very least their flagship P9 table, but they don't. $5k doesn't even get you a record clamp? Maybe there's a reason?
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
Agreed. My libraries in both Los Angeles County & Alameda County have a lot in store for me. Retrieved my Anoushka from same.Got a late start by several hours tonight - just now getting in session with my beloved WA 6 Special Edition. Briefly threw iTunes into 32-bit mode w/Amarra+Lion - sounds much better than it has since Lion install out of the box. The 64-bit plug-in is the suspect!
Next hour will trash preferences; plug-in and then run iTunes properly (preferably) in 64-bit kernel & extensions and see what the payoff is. If necessary, will uninstall/re-install Amarra.
Good point, Eee Pee. Something to consider.
Better to be safe than sorry I suppose.
