Davy Wentzler
Member of Trade: eXtream Software Development / Audio Evolution
- Dec 18, 2012
Thanks for the great app however it does not really work well on my devices. I use USB Audio on DP-X1, Fiio X7 and Cayin i5 over DLNA(Samba). It does not work on Cayin i5. It will sit there and looks like freezed the player after hitting play button. On DP-X1 and Fiio X7, it will repeat a few seconds of different fragments. It is very hard to describe. Like I am playing A song, it will sit there for about 10 seconds and then starts to play for 5 seconds and then repeat the beginning of the song. for 6 seconds, then repeat again. Later, it will jump to 30 second position and play from there. It seems like your code is mis-handling network buffer. Pointers were not updated? I don't know but it renders your app almost unusable on my devices.
Another issue is I have several NAS. I added all of them in your app. Then if I create a play list for the 2nd NAS, it will not play and complain network error for wrong password. It seems like it only uses the first NAS credential even the tracks are from 2nd NAS!
To test it is not my network problem, I installed HiBy and it plays tracks perfectly without dropping or stuttering. I hope you can fix it soon.
Please contact support at info@extreamsd.com, this is not something we can handle in this forum.
