Oct 4, 2016 at 12:25 PM Post #871 of 6,408
I've just started using UAPP and everytime I add new files to my sd card it doesn't automatically update in the app library like it does in Poweramp. Is there a way to enable this in the app?
Thanks
Oct 4, 2016 at 12:31 PM Post #872 of 6,408
Thanks
Yes, i just saw that as well. I thought it did before.
Oct 6, 2016 at 7:43 AM Post #874 of 6,408
  Please add support for Spotify & Amazon music accounts.
You really don't need an audiophile music app to listen to lossy music.
Oct 6, 2016 at 7:54 AM Post #875 of 6,408
I totally disagree with this but ymmw of course, and it obviously does...
Oct 6, 2016 at 8:02 AM Post #876 of 6,408
Yes, the original 'Android DB' (which can be found at the bottom of the selections of tracks, artists etc.) will still update correctly - to update the UAPP database, you need to back out to the album / artist listing, press the three dots (top right) and refresh (or whatever the terminology is) the database - me personally, I clear it and let it scan again, as if you just update, it keeps any tracks on there that may have been removed.
Hope this helps,
Oct 6, 2016 at 8:45 AM Post #877 of 6,408
Some people don't think one needs to listen to lossless music.
Oct 6, 2016 at 12:36 PM Post #878 of 6,408
In which case, status quo...
Must be said though, that lossy codecs are a helluva lot better then when they first came out, both in detail retrieval and also general availability.
Remember the original iTunes... 128kbps aac, nasty!
Oct 7, 2016 at 12:58 PM Post #879 of 6,408
Ooh, thank you Davy Wentzler and team, exciting to see the update with the LG B&O hardware volume fix, can now run bit perfect :) I swear going from software to hardware, and with bit perfect enabled that the SQ is more precise, both tonally and in terms of positioning :)
Awesome as always :)
Oct 8, 2016 at 9:36 AM Post #883 of 6,408
I'm having the same issues. Is it to do with Android rather than UAPP and Tidal?
I suspected so and tried all the internal server error fixes to no avail.
First of all you need to make sure you are running a UAPP version of 3.1.7 or higher. If you are running that, you can try clearing the app's data/cache.
Oct 8, 2016 at 9:50 AM Post #884 of 6,408
Hopefully, with the fix appearing to work brilliantly for the B&O DAC and hardware volume with the newest version, for the next update we can get rid of the warning re the volume? :smiley:
