Thanks! And i've got the latest release and works now after changing the configuration. That's awesome!UAPP is being updated for full support of the M3X at 16x. The changes have already been done and the new version should show up on the Play Store soon.
https://www.head-fi.org/threads/new...lable-march-2021.950199/page-38#post-16311607
USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
Thanks.
It would have been great to be able to stream the EQ'ed music to another client.
Thanks.Bubbleupnp does support Tidal (and Qobuz). I believe the eq would need to be done on the client device itself, but it may vary. I tried with my Denon receiver and there is no eq option in bubbleupnp for that client. Note that when playing locally on my DAP, there is an option for eq which loads the android system equalizer panel. Sorry if I'm not much help.
rlw6534
The new version hasn't showed up for me yet, but I'm not sure how Google Play works on offering updates. Out of curiosity, what is your version number now?
It shows v5.9.9.6 and the configuration was told by another experienced m3x user. I only get it from google play directly.The new version hasn't showed up for me yet, but I'm not sure how Google Play works on offering updates. Out of curiosity, what is your version number now?
rlw6534
OK. That's not the M3X updated version, yet. With the upcoming version, no configuration is needed, other than bitperfect.
rlw6534
Thanks.
Thanks.
I did discover that UAPP has a DLNA server that starts with the renderer service. Unfortunately, there is no control of clients from UAPP, so you still can't eq (or even start and stop) what is playing remotely.
Anyway to buy and use on devices without google play?
If you install Lurker firmware, you have access to playstore.Anyway to buy and use on devices without google play?
Hello all. Question about the FiiO X7.
Has anyone ever gone thru one or more of the verification steps under "VERIYFING THE CORRECT WORKING OF THE DRIVER" on the hires audio driver page with the X7?
https://www.extreamsd.com/index.php/hires-audio-driver
Hoping to save time from having to do it myself if this is already known, is why I ask.
Does the developer of UAPP respond in this thread? If so, is there a reason Deezer is not supported? I have searched online, and emailed the developer, but I cannot get an answer.
I currently use Tidal, but am geting frustrated with the lesser sounding MQA being pushed on me instead of 44.1/16. Often, both are available, and invariably 44.1/16 sounds better to me than MQA (I’m using Chord’s HMS and TT2). But more and more tracks and albums are only available in MQA. Tidal will not respond to my question about giving us the option of avoiding MQA. At least with Deezer you know it is always 44.1/16. But Deezer without UAPP is not even in the same ballpark as Tidal with UAPP.
DBaldock9
It's been a while, but Davey does answer questions and post here every so often.
He can be reached at: support@extreamsd.com
Deezer doesn't have a paid API, but they will consider developer partner agreements - https://support.deezer.com/hc/en-gb/articles/360011538897-Deezer-FAQs-for-developers
Have you tried the Qobuz service that UAPP does support?
For me, there's more music that I enjoy listening to, than on Tidal - so I switched subscriptions.
It seems like a lot of their music is streamed in CD quality (which may work better over WiFi).
vanhalen26
- Mar 28, 2009
Davy has been very responsive and helpful when I’ve emailed him directly. Just keep it brief and straight forward for him and he’ll probably get back quickly.
I’ll try to contact him again. We will see.
As far as Qobuz, I’d love to try it, but it’s not available in Canada.
He said “it's technically not possible. We need access to the actual audio data and the stream of Deezer is encrypted and the SDK only allows remote playback of tracks in their own app.” So, won’t happen.
vanhalen26
- Mar 28, 2009
Qobuz will work in Canada. You need a VPN to sign up, and it’s fussy and detects/blocks some VPNs, but once you have a working login/pass it has been working just fine.I’ll try to contact him again. We will see.
Total: 39 (members: 0, guests: 39)
