Hmm. A bit larger than I hoped, as a source streamer only for a E1DA PDV2. But... Seems it may be able to output USB Audio in HD natively, and supports apk installs. Love that it whitelisted Roon. Would like to use UAPP but, if I dont have to.... hmm. Thanx!Have you tried the Fiio M6?
USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
After reinstalling the UAPP program, all sampling frequencies are output to the external DAC correctly.Today I’ve been trying for several hours to output sound to an external DAC (Chord Qutest) through the USB interface. All my experiments have shown that DSD is not directly transmitted at all, the program writes that it does not “see” the corresponding DAC. PCM of any sampling frequency (from 44.1 up to 384), as well as DSD with conversion to PCM, is output to the DAC only with 96 kHz parameters. This frequency is shown by the DAC. I tried everything settings, nothing changes. It is very strange, given that the developer of the program declares the exact opposite - a bitperfect transmission. Perhaps this is some kind of incompatibility with the Hiby R6 Pro.
Why it was different before the reinstallation - I can not understand
I did buy into the Roon eco-system. Mainly to take advantage of Raspberry PI DACs with or without RoPieee. But not only that; linking of multiple zones, time delay, and DSPs top among them. But I agree that there are -numerous- UI/UX aspects I disagree with, very strongly.I once tried Roon. Everything is very sad there (not convenient) with the library for me. And the price is not for everyone![]()
Hey @Davy Wentzler I recently updated to Android 10 on my S9 and now my Ztella only seems to work in bit perfect mode...? So I can't use the eq etc with it anymore... I went through all the setting etc. And saw nothing obvious.
Also it all works as expected with the headphones just plugged in directly to the phone.
Any ideas?
Thanks!
Any ideas?
Thanks!
Say... are there any reps of Audio Evolution / eXtremeSD here; not sure which. Edit: @Davy Wentzler or other...
There is this pretty nifty little Android based player, the FiiO M6, that could be bettered by the use of your UAPP it. However it does not run the Google Play Store. And my attempts at installing the Play store on it failed:
I had a thought. If we could purchase a separate unlock apk fom you like some other players I purchased in the past, maybe from our phone that has google play if you dont want to deliver it directly which I do understand, then manually copy it to the M6 and side-load install it (FiiO lifted the whitelist restriction, so now anything can be installed on it) like the UAPP app itself, it would not need to check license against the Play Store and we'd be able make use of this fantastic player on that little M6 device.
Thanx!
After trying several different versions of installing Google Account, Service Framework, Play Service, and Play, using what worked on my Amazon Fire Tablet it's always the same. First two install. Once Play Service is installed, the Service Framework goes into a loop of 'App has Stopped'. Luckily one can either restart in Safe Mode or click quickly between modal error dialog boxes and uninstall the Play Service.
Thanx!
scottm18
- Dec 27, 2016
Seems like LG has killed DSD/DoP playback on Android 10.
This is the main reason I'm back on here because I was looking into the V60 (to replace my V40)...but apparently LG has screwed the pooch yet again. PCM conversion is unacceptable for DSD playback because it defeats the whole purpose of this phone's audiophile capabilities! With this phone and quality headphones you can easily hear the difference.
Davy...any news on that front?
LightBlue77
Same applies to fiio's new flagship, m15, there is an answer from davy saying it might be possible to have uapp on Android devices without play store. I think if enough people will request this, eventually they might make it available.There is this pretty nifty little Android based player, the FiiO M6, that could be bettered by the use of your UAPP it. However it does not run the Google Play Store. And my attempts at installing the Play store on it failed:
Thanx!
All I need is UAPP for devices that don't support Play Store...
jmills8
Previously known as bmiamihk, jmills2
UAPP for ?All I need is UAPP for non Google Play supported devices...
devices that don't support Play Store (edited).UAPP for ?
jacko5
Not sure what you mean.Are those songs not tagged as same album?
All songs are in one folder which has 3 folders inside .. one for each cd.
I have now just deleted the album,as it was annoying me.
Cheers.
jacko5
I have now just deleted the album,as it was annoying me.This has happened to me, too. What I've done to get rid of it is rescan my folders. The multiplicity of copies may be because uapp might not drop erased older copies of folders.
Take this for what it's worth. I'm no expert!
Cheers for the info though.
In this case, UAPP becomes available to everyone without any payment. The next day, the * apk file will appear on the network, on Russian forums and torrents.
I do not think this is the right decision.
LightBlue77
They could make it run based on some credentials authenticated online.
But have you noticed that Davy, the developer, is not active for a week or so?
I chatted with Devy the last few days via email. He managed to make sure that the wavpack with dsd is played in native mode. I think he is preparing a new version.
Total: 24 (members: 0, guests: 24)
