audiophilefan
- Jul 1, 2015
Thanks for the heads-up. In that case, will try to buy that one first before the TRN V90
The point of diminishing returns for IEMs is $50, a price point where the likes of the Tin T2 and TRN V90 comfortably sit. Those are the best examples of absolute value for money (metal build, good enough cables, good tuning).
If you start to tread the $100 mark then you hit the likes of the Sennheiser Momentum, Ibasso IT01, and Fiio FH1, FA1, or F9 (they've gone cheaper). The plus you get in this price point is overall better accessories and a better overall package. In terms of sound, it's hard to upgrade from your Momentums. Maybe get the 1More Triple Drivers or Quad Drivers but their cables are non detachable. As I said you get great IEMs at $50 with detachable cables.
In a nutshell, you get better value under $50, always. But it depends on what you prefer. You usually get a more neutralish/accurate sound at $100 (this is the point of diminishing returns for over-ears). Audition your options if and when you can. Happy hunting, brother!
