analogsurviver
- Jul 2, 2012
The difference between the way different bass instruments sound is due to harmonics. I'm sure you've heard lots of examples of bass that sounds like a plucked string bass with several octaves of harmonic content to the sound from the pluck all the way down to the fundamental. And I'm sure you've heard funk bands where the bass player dials out all the harmonics and plays a bass line that you feel more than hear as a melody. Harmonics are the thing that makes one instrument sound different than another.
Boy! You can say that again! When the whole jitter thing was hot, I realized that it dealt with an area of sound reproduction that I hadn't considered before. So I spent a week diving into it and researching it and I puzzled it out. At the end, I realized that I had wasted a whole week on theoretical sound that didn't exist in practice. And when it comes to timing errors, the best turntable introduces more error than the worst CD player by several orders of magnitude.
There is a tendency among high end audio salesmen to look for a theoretical problem that they can advertise that they have discovered a cure for. I'm beginning to think that RF in USB qualifies as the latest and greatest version of this. I'm getting better at asking the questions that makes it easier to spot them.
That isn't the issue on that particular album. It's just plain old different mastering on the CD than the SACD. In order to compare CD to SACD fairly, you need to find an SACD with the exact same mastering on the redbook layer. It's harder than it seems. When I was doing my listening test on this, I discovered that there were often big differences between the layers on an SACD, especially with rock albums. I found a Rolling Stones SACD where it wasn't just different mastering, the redbook layer had an old mix done for LPs and the SACD layer had a brand new digital remix. Everything about the two were different.
If someone wants to do a comparison test for themselves, I'd suggest using a Pentatone disc. They only sell SACDs, but many people who buy them don't have SACD players and only listen to the redbook layer. This means that they are not motivated to hobble the redbook layer to justify the SACD format.
When I did my test, I used this Pentatone disc, which was recorded in native DSD and has a redbook layer that is identical to the SACD layer. Neither me nor my friend who was helping me with the blind test could tell any difference between the layers.
http://www.pentatonemusic.com/stravinsky-lhistoire-du-soldat-die-deutschekammerphilharonie-bremen
One thing to keep in mind is that the CD layer is usually quieter than the SACD layer. If you don't level match carefully enough, you will think the SACD sounds better because of the volume difference.
Woodyluvr, I think what we are seeing is an absorption with the self, a hyper focus on a single topic, and the inability to treat others as people. That might not be something that's able to be changed. A little vacation will probably help.
on another subject...
As I explained before I think that spending money on things that don't matter fits under the definition of expendable income. Anyone is free to spend money on whatever they want. They can throw it in the fireplace just to watch it burn and I'd say that is their right. But you yourself know that you can't hear a difference above 256 compressed audio. Buying something more than that for purely theoretical reasons when you know that it offers no practical or aesthetic benefit is certainly unwise, and perhaps even kind of dumb. If you have expendable income, I think smart ways of spending it would be on travel, or more music, or art or literature. All of those things can enrich your life in tangible practical ways. Superfluous zeros and ones do absolutely nothing except take up space on a shelf or fill up a hard drive with digital packing peanuts. It's a waste of money and a waste of space.
Here's an analogy for you... The quality of a Christmas present isn't judged by the size of the package. I didn't realize that when I was 5 years old, but I learned that by the time I was 9!
I have - most clearly - explained that both CD and SACD layers on the disc in question ( Opus 3 CD19423 )
https://www.discogs.com/Omnibus-Wind-Ensemble-Music-By-Frank-Zappa/release/1820934
are the same mastering. Which is different from the earlier CD only release ( Opus 3 CD19403 )
https://www.discogs.com/Omnibus-Wind-Ensemble-Music-By-Frank-Zappa/release/4102340
And I said the CD and SACD layers of CD19423 do not sound equal. RBCD is just plain too slow to match the speed original analogue tape has - there is no way it can match the pulse response obtained by SACD/DSD64, which can take advantage of a superiour analogue master tape.
I do not know or claim similar for other SACDs - they may well be actually different masterings for CD and SACD layer. But NOT in the case of CD19423 !
