Gregorio has said, and asked, a few things that have me a bit confused here.....
For example, we seem to agree that, at 30 kHz, there is significant attenuation over distance.
And Gregorio keeps pointing out that, at sixty feet or so, there wouldn't be much of it left at all.
However, in most multi-track recordings, there's a microphone a few feet above the cymbals.
And, at a distance of a few feet, the maximum attenuation, even at 30 kHz, is only a few dB.
(I've even seen a few microphones actually stuck inside the cymbals).
That suggests to me that the attenuation at further distances is somewhat irrelevant.
(Are they deliberately rolling things off at 20 kHz so it will
sound like the microphone was 60 feet away?)
Gregorio and I seem to agree that most engineers and performers choose microphones by "sound".
However, we also seem to agree that most studio microphones have a limited high end response.
And, as Gregorio points out, there don't seem to be many if any "microphones for cymbals".
However, while Gregorio seems to imply that there are no studio microphones whose response extends above 20 kHz, or at least exceptionally few, he also suggests that, like any "interesting new technology", they have in fact "been tested over and over again over the years".(Am I to assume that tests were actually conducted to see whether listeners found microphones with extended high frequency response to NOT sound better? If so, I'd be curious to know if they used equipment for those tests designed to record and reproduce those frequencies, or if they ensured failure by testing them in conjunction with a signal chain not designed to reproduce what they recorded.)
(It seems to me that those recordings, made with those experimental microphones, with the response that extends to 30 kHz, that we know contain the ultrasonic harmonics that are produced by cymbals, and are only attenuated by a few dB at such close distances, would be ideal test files for testing whether people can tell the difference between CDs and high-res recordings. And, in fact, those are the microphones I would be using for all those tests. I guess luckily they do exist after all. So, are we to assume that every studio has a few, languishing in the back of the closet, because nobody thinks they sound especially good? )
I do agree that the concept of "better" is somewhat vague... and excessively open to interpretation. For example, we could argue whether a meter with 0.05% accuracy is "really better" than one with 0.5% accuracy, if all you really need is 1% accuracy, or whether a car that can go 120 mpH is "better" than one that can only go 80 mpH, so perhaps we should settle for saying "with technical performance that exceeds the minimum necessary requirements". (However, just as that Jaguar will actually do 120+ if you floor it, a 96k file is most certainly able to really reproduce frequencies up to 45 kHz if they are present.)
My problem here is that I keep seeing what I might call "an appeal to status quo".
Basically:
- Nobody does it because everybody knows it doesn't matter.
- Everybody knows it doesn't matter because nobody does it.
Well, maybe it's time to break the loop, and do some actual testing.
How about we start by recording a few drum solos, with lots of cymbals, using one of those long-forgotten microphones with the response to 30 kHz, stuck five feet right over the drum set? We'll record it at 24/96k so we know those ultrasonic overtones are really preserved (actually they're technically not harmonics with a cymbal). And we'll make sure to use a microphone preamp with a response into the ultrasonic, and confirm on an editor that those frequencies are really there. Then we'll play those recordings back, on speakers or headphones, which we've tested to ensure that they actually have a response that extends to 30 kHz or so..... and, once and for all, confirm how many people hear a difference and how many don't (and if that number is zero or not).
And, yes, selling people equipment that technically performs better, for a higher price, is often profitable.
And, for this reason, many companies are going to try to sell you their highest performing product.
Ferrari and Jaguar specialize in selling very expensive products that probably perform far above any need.
But Volkswagen had a very good run selling "a really cheap car that got the minimum job done very well".
However, neither has any bearing on what you or I, or anyone else, needs or wants.
I'm also a little confused about exactly what you mean by "damping of the sound". We have the attenuation experienced by the sound over the trip from the instrument to the microphone, which is all that will affect the sound arriving directly at the microphone from the source - over the shortest direct path. Then we have things like surface absorption, which will affect later reflections, and so the long-term averaged response. So, as those other losses increase, the average long-term response will get duller, but the original "bite", experienced over the first few tens of milliseconds, will be controlled only by the attenuation experienced from direct losses.) Also, as Gregorio pointed out, the attenuation increases significantly with distance..... so, for a microphone positioned five feet over the drum kit, we can probably ignore everything everything except the sound reaching the microphone directly through those five feet of air (with their 4 - 5 dB of attenuation at 30 kHz). We don't need to even consider all that stuff that's 50 dB down after reflecting off the audience.
Yes, cymbals sound quite different when you're standing three feet away than when you're standing twenty feet back in the audience. But, most of the time, they do in fact end up being recorded from three or four feet away - and not 20 feet. And, if 6% of the energy of the cymbal is at ultrasonic frequencies.... Then, one meter above the cymbal, where that overhead microphone is mounted, it's only down about 3 dB. That's still quite significant.
And, if it turns out that even a few people can notice when those frequencies are present...
But "they're never included in most commercial recordings anyway"...
Then I guess most commercial recordings fall short of "the limits of human hearing"...
Which sounds to me like a problem worth correcting...
(Especially since we both seem to agree that it wouldn't be that difficult to do so.)
I will always maintain that the recording engineer counts as "one of the artists"...
Therefore, if the recording engineer PREFERS to record cymbals with a microphone limited to 20 Khz....
(Or if he or she prefers to use a microphone that's limited to 10 kHz for that matter.)
That is certainly his or her business...
But then it's a personal preference... (or "artistic judgment")...
It's neither "a technical limitation" nor "a limit of human perception"....
1. By and large true.
2. Also true.
2a. Not entirely true but again, by and large true.
3. Sort of true.
4. Correct, it doesn't by itself prove that.
5. And there we have it yet again! Some true or partially true statements followed by a completely false statement and a totally fallacious conclusion! You have in fact got it entirely backwards, we "go with the assumption" precisely because we HAVE "tested the possibility"! The reason we assume >20kHz content isn't useful is because ALL the evidence and practicalities of music recording creation demonstrates that it is NOT useful, while there's NO evidence to suggest that it might be, which incidentally is why most studio mics are designed to have little response above 20kHz!
1. Interesting, you do in fact have at least a very basic idea of why mics are chosen. Why then do you keep inventing scenarios and quoting mics which are contrary to this requirement? Hmmm!
2. Agreed, that's a logical idea, nothing wrong with it at all. However, in reality it's nonsense because we have done exhaustive tests and cymbals do not sound better when recorded with mics whose response extends to 30kHz and that's precisely why, after 20+ years of testing, there are no mics specifically designed for recording cymbals!!!!
3. You're joking right? If you suddenly had access to a new technology, what would be the very first thing you'd do with it? Wouldn't you test those new technology aspects exhaustively and start with the most likely and common source to expose that technology? So, of course I've actually tried it, countless times over many years and so has pretty much every experienced commercial sound engineer.
1. Yes, it is unreasonable because it's just a marketing lie that you're getting "something a lot better than the minimum". What you're actually getting in the best case scenario is something that's exactly the same and commonly, something that's actually worse!
1a. Is it unreasonable to buy and pay extra for a sports car that is advertised as a sports car with 120MPH top speed but at best only performs the same as a ford fiesta and at least some of the time can't even keep up with a ford fiesta?
1b. And have you, as a member of the trade, ever considered the possibility that convincing audiophiles they're getting something better than they'll ever need and omitting the fact that they've already got something better than they'll ever need (by falsely characterising it as not good enough or "just good enough") is a profitable marketing tactic?
1. Ideal, two falsehoods/fallacious tactics in one sentence, I'm impressed! Firstly, how come you haven't seen much actual DATA when so much of it has been presented, did you "inadvertently" miss it again? (For example
this post #10636). Secondly, the old audiophile marketing tactic of providing "some" actual data but "inadvertently" ignoring the other relevant data and thereby misrepresenting the facts/data! ...
2. Under more realistic conditions (50% humidity, as musical instruments do not cope well with low or high humidity), the high freq absorption is 0.937dB/m which at say 20m is a loss of 18.74dB. However, as stated in the previous point (and in previous posts!), that is not the only relevant data! There is also damping of sound level vs distance, IN ADDITION to purely high freq absorption. At 20m (relative to say 0.5 meters) we loose 32.04dB, so now our 30kHz signal is down by 50.78dB. Another piece of ACTUAL DATA you've ignored (despite the fact it's been posted several times) is that in the case of a cymbal, only about 6% of it's energy is above 20kHz. So, we've got a relatively small amount of signal >20kHz to start with and what's left is going to be attenuated by over 50dB. We should also consider the rising thermal noise of mics and mic-preamps with frequency, which definitely comes into play with signal loss over distance and If we're talking about a live situation, then we should also include the significant damping cause by the audience itself. After all this attenuation, there's simply nothing left to record above the noise floor, let alone hear! So yet again, round and round in circles we go, caused by you yet again (inadvertently?) misrepresenting the facts. Are you ever going to stop insulting this forum?
1. True.
2. True but only if you (inadvertently?) omit the relevant, uncontested facts and (inadvertently?) ignore some of the laws of physics!
3. True but I ask you again (because you refuse to answer) do you or an audience ever sit with your ears one inch away from the snare drum during a performance or a couple of feet away from the cymbals? Have you ever tried it? Have you any idea what it sounds like? Do you even have any idea how preposterous it would be?
I'm not disputing that given the right conditions 22kHz is audible, in fact quite the opposite, I've stated that given the right conditions, everything is audible, even much higher than 22kHz! The relevant question is: Do those conditions ever exist in the recording and reproduction chains of commercial audio (or live performances) at any reasonable listening level? Firstly of course, no one ever makes commercial audio recording of only a 22kHz tone. >20kHz content (when it does exist) is ONLY the result of higher order harmonics and is tiny in amplitude relative to the audible band. Even if it were possible to hear 22kHz at a level of say only 100dB, in commercial audio recordings that means the peak level (in the audible band) would have to be at least 130dB and typically, more than 140dB. If instead of 22kHz we were talking about only say a 15kHz signal, it's extremely unlikely that at >40dB below the (more audible band) content it could be "heard" in a commercial audio mix. So, what's the implication of the claim, that our ears perform better at 22kHz than at 15kHz? Admittedly there's essentially (AFAIK) no research in this area, a fact which is misrepresented/abused by those with an agenda. The reason there's no research is that it is too dangerous to carry out such research, peak levels of 130dB and above will cause pain and damage, >140dB will cause almost instantaneous damage. In other words, the reason the research has not been carried out is itself evidence/proof that it's inaudible.
What's disingenuous is that those supporting the claims actually seem to have some understanding of the facts but just abuse them depending on what they're arguing about at the time. For example
@Phronesis stated "
I think it's important to use a pure tone, otherwise harmonics can confuse us about what's going on." - As seems to be so often the case in these disputes, a true argument that's used to support one specific point is in fact self-contradictory and an argument against the claim itself. While Phronesis' statement is true, in practise it supports the argument AGAINST the claim because very high/ultrasonic frequencies in commercial audio recordings ONLY exist as harmonics and high order harmonics to boot! These tactics have gone way beyond tiresome!!
G
