zephyrstar
I wouldn't consider them a bass monster. They are not bass shy either, I would describe them as bass accurate. My Atlas are more in the bass monster category, but sometimes I want that
I’m in exactly the same boat. I also have the Atlas as well and that is a different kind of big, full sound. Not as detailed or refined as the 1er, but sometimes it just gives me what I feel like.I wouldn't consider them a bass monster. They are not bass shy either, I would describe them as bass accurate. My Atlas are more in the bass monster category, but sometimes I want that
Baitit is good unless you want a different look or 2.5mm plug.
Hey guys, is stock cable good enough or is it better to upgrade it?
I think it’s good. I tried a balanced 2.5mm **** cable and preferred the stock 3.5mm oneHey guys, is stock cable good enough or is it better to upgrade it?
I find the stock cable to be very good as opposed to the stock cable for the full size Z1R which I didn’t find all that good
I think stock cables for both are good. I got a kimber cable for my full size z1r and actually prefer the stock cable.I find the stock cable to be very good as opposed to the stock cable for the full size Z1R which I didn’t find all that good
Try the Symbio wide bore tips. They work good for me.I'm looking for some new tips for my Z1R and I'm interested in specific geometric parameters. Does anyone know of an online "database" of IEM tips, with measurements?
Alternatively, does anyone know some quality tips that are shorter than the Sony/Final tips? I'm talking about tips that don't extent as much as the Sony/Final beyond the end of the metal nozzle.
