wormsdriver
3.5mmAre the female connectors 2.5mm or 3.5mm?
3.5mm
Thank you. The girth and weight of the cable in my GH1 is the reason I don't use it as much. I just found out about this mod and I'm very interested.
The Grado headphones have always seemed light and comfortable to me. The cables on the other hand are like boat anchors. The kit solved that problem perfectly!
IMO if your Grados are keepers, the Beautiful Audio cable adapter kit is a must have addition!
If you are willing to remove the drivers I'd suggest SMC jacks since they fit in the existing cable hole and are even lighter and cheaper:Thank you. The girth and weight of the cable in my GH1 is the reason I don't use it as much. I just found out about this mod and I'm very interested.
My RS2e with the drivers removed and the SMC jacks on the far left
After installation of SMC jacks and some G-pads
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Hello everyone!!
A very dark wood for a clear sound, very clear sound.
I need to "break-in" the drivers (RS-2e) that I use for "hear" the wood, Incredible sound for now. Finally I will mount a pair of Nhoord Red, I hope.
Cheers!!
Ouh Yeah!!! A leather headband is "mandatory", Thanks!!... I prefer L-Cush style pads.Nicely done! Next, a leather headband too, and some TTVJ flat pads, right?![]()
