Cruelhand Luke
I appreciate the input....I have had good results with magnets before, but I agree with you, it didn't seem to have much effect on the Grados. I have tried sorb in the past, didn't see much effect, but I also wasn't super patient about trying out a million different combinations. For some reason the one area of headphone tuning I do not enjoy is damping...it's probably my ADD, but taking them apart, damping, reassembly, listen...aaaand then taking them apart again gets old really quickly for me. That's why swapping out the cups appeals to me, the solid aluminum cups takes care of the damping itself. I very strongly believe that resonances in the cups is an area that manufacturers neglect in their lower line headphones, which causes the cheaper headphones to sound cheaper.I've tried the magnets and to me it does not have the same effect as dynamat which is also different from sorbothane.
When I tried the magnets they had no effect on the sound to me, maybe I didn't use enough or they were too small (10mm), only used 4 magnets, 2 each side
Dynamat seems to affect mids to lower frequency mostly, I usually use a 10-12mm strip around the cups, I've also lined the edge of any open vent holes, using dynamat extreme
Sorbothane seems to affect all frequencies by getting rid of unwanted vibrations, have had better results with duro 70 (.125) on back of magnet housing but for my HE400 and SR009 the duro 50 has better results to me.
It's really interesting actually...I mean, something as simple as an IEM like the KZ ZSA which has an all aluminum shell, versus the plastic shelled KZ ES3...They use the same drivers, in the same number and configuration, but I can 'hear' the metal body, it's cleaner, more crisp...almost sterile by comparison. (in a good way).
