larry piencenaves
hey guys may i know if L-cush pads will make some signifcant sound difference in my grado sr60e with stock pads? or its just the same?
Agree with @Shoewreck about L-pads making a difference in the sound over the stock S-pads. Also, there is a difference between Grado OEM L-pads and generic / Earzonk L-pads. While you are thinking about pad rolling you might also want to try some generic G-pads which I like a lot due to better comfort and a slight boost in the bass and sound stage.hey guys may i know if L-cush pads will make some signifcant sound difference in my grado sr60e with stock pads? or its just the same?
@Hifisnubben what jacks did you try to use in the cups? I've been using SMC jacks since they will fit in the cable hole of most cups without too much effort. These are the jacks I use:
https://vetco.net/products/smc-female-chassis-mount-connector (works great for TH-X00/600/900 mod)
or
http://www.ebay.com/itm/1pce-Connector-SMC-male-plug-bulkhead-for-1-13-cable-RF-connector-straight/281127310750?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649 (longer thread area)
Great warning to others and sorry it happened to you. I think if the cups didn't have the cable slit it might have worked out but its a great reason to invest in a Dremel tool with a good range of bits, I actually have 2 of them since I got one for a retirement gift.
I tried mini xlr. At the objections of a friend i used inferior tools and methods that resulted in what is shown in pic. My patchwork turned out quite ok fortunally.
Just wanted to warn so that people can lern from my mistake and not repeat it
To be honest i didnt consider SMC until after the damage was done.
These have Grado dna, Nhoord drives, and sound as wonderful as they look:You could try one of the alternate drivers from Nhoord, Symphones, or Elleven Acoustica. Might need some work to fit the these drivers out just get the one of the drivers and some wood cups
I do have a dremel....now
We learn from experience and im happy with the result still. If you dont know it was broken before its hard to spot now.
All and all it was a interresting build
