Ok so I could use an opinion, I am considering some wood cups for my sr225, question is, just how much of a difference do wood cups really make, I have heard everything from a ton of difference to the fact that if a hardwood is used, it really does not differ much from the plastic cups and it won't really be noticeable. I don't want to invest another $80 on a pair of headphones that cost me $100 used only to find out there really is not a difference. I don't mean to open a can of worms, just a couple of experiences. The wood cups I am considering are a hard wood.
Thanks,
James
post your grado mods....
Jbmorrey
- Dec 21, 2014
What about your Denon D2000, did they sound better in Maple cups or plastic?
Well, unfortunately, I purchased them with the wood cups installed and the plastic ones came with it. Now that I look back, when I was restoring the wood cups, I could have installed the plastic cups to see what the difference was..... Alas, I did not do that. So I still don't know. Good thought though 7keys, wish I would have thought of that at the time.
James
James
Dis you ever read this thread?
http://www.head-fi.org/t/686212/the-great-grado-experiment-4-tonewoods-tested-more-to-come
Jbmorrey
- Dec 21, 2014
7keys, Pretty good read, I went straight to the Maple, which I assume would be similar in regards to a hard wood like the Lignum Vitae wood cups I am considering, and it sounds like they are not too favorable for mids(vocals) as this is the type of music I listen to the majority of the time. Perhaps I should be looking for walnut cups, which the review stated brought out the mids and treble the best. Thanks so much for that link, it pretty much answered my question. I know you have a lot of experience with wood cups, do you feel I have come to a correct conclusion?
Thanks,
James
Thanks,
James
Thanks,
James
That was soft Maple, Lignum Vitae is much harder on the janka hardness scale.
Lignum Vitae 3710
Hard maple 1450
Soft Maple 950
Red Cedar 350
The Janka hardness test measures the resistance of a sample of wood to denting and wear. It measures the force required to embed an (.444 in) steel ball into wood to half the ball's diameter.
Jbmorrey
- Dec 21, 2014
Lignum Vitae 3710
Hard maple 1450
Soft Maple 950
Red Cedar 350
So what kind of sound should I expect from the Lignum Vitae? I did like the way they rated everything in that thread you linked, it was very helpful.
Thanks,
James
Thanks,
James
I never tried Lignum Vitae. We were going to have a round two with exotic wood but never got a round to it.
Fleasbaby seemed to like his, maybe he could chime in.
Someone just gave me a round to it. I better start round two.
fleasbaby
Member of the Trade: Wabi Sabi Headphones
- Jul 8, 2011
The Lignum sounds way better than Maple in my experience. The soft Maple was aenemic, the Lignum isn't.
Jbmorrey
- Dec 21, 2014
I am awaiting a pair of wood cups for my 225's. I already have the drivers liberated from the plastic cup, but obviously I will need to unsolder the connections and then re-solder. I don't have any solder at the moment and I am about to order some sold wick to remove the solder. Is there a specific type of solder I need to purchase? And recommendations. I have never soldered electronics, only slot car engines!! A looooong time ago, so I am would appreciate any tips.
James
James
uglyjoe0124
- Dec 17, 2012
Hi JamesI am awaiting a pair of wood cups for my 225's. I already have the drivers liberated from the plastic cup, but obviously I will need to unsolder the connections and then re-solder. I don't have any solder at the moment and I am about to order some sold wick to remove the solder. Is there a specific type of solder I need to purchase? And recommendations. I have never soldered electronics, only slot car engines!! A looooong time ago, so I am would appreciate any tips.
James
With the grado drivers you will find that you will need to do the soldering pretty quickly at a high temp.
I used a soldering pump which would suck the solder of the tab as soon as it was hot enough to move .
There are tiny little wires hidden and if to much heat is used for to long a period will become disconnected.
I always tend to use cardas solder as I'm used to that and it also makes a lovely connection.
I hope this helps
wormsdriver
so earlier today I received a pair of ps500. While I think they do sound very good, I find them just a bit too boomy for my taste. I did notice that the Grado highs and mids are still there, just a bit over shadowed by the boomy bass though.
I put on a pair of G-cush on them and while the sound improved quite a bit the bass was still a bit too much for me.
Holding up the cups up to the light I could see that there is four holes punched in the stock configuration so I decided to cover up two of them...
WARNING: NOT FOR THE FAINT OF HEART!...
![](https://www.head-fi.org/attachments/1596787/)
![](https://www.head-fi.org/attachments/1596788/)
![](https://www.head-fi.org/attachments/1596789/)
I was able to hear them side by side briefly next to the PS1000 before coming to work and I'm very pleased with the initial results. I thought they sounded VERY close to the PS1000, although not quite there. They still need the heavier cups to get even closer in sound...
fleasbaby
- Jul 8, 2011
[COLOR=22229C]
[/COLOR]
[COLOR=22229C]
[/COLOR]
[COLOR=22229C]
[/COLOR]
You sir, are truly a pioneer.
JoeDoe
- Apr 12, 2013
This man lives on the edge!
uglyjoe0124
- Dec 17, 2012
I opened up my HF2 cups to find just one hole madeThis man lives on the edge!
uglyjoe0124
- Dec 17, 2012
Total: 8 (members: 0, guests: 8)
