Arty McGhee
- Apr 14, 2014
definitely practice on some cheap or broken headphone / eletronics
used sr60's can be had pretty cheap for prac
take a photo with your phone before you start
you don't have to solder to the driver pads, cut the wire 1/2" before
and solder to the wire, use thin solder, presolder or tin everything
don't use too hot of an iron, i use this guy, its $18.50 on amazon works great
don't get discouraged if you mess up take a break and go back to it
good luck
diy or die!
Just finished the mods on my sr225i ! Mods are as follow:
1) Remove the "sr225" button from the grill.
2) Remove the inner plastic holder of the metal grill. I had to glue back the grill!
3) Remove & replace the front silk grill
4) Replace the plastic cup holders with "allen" screws w/ locking nuts!
5) Libarate the drivers and install them back so both drivers' soldering position looking UP!
6) Re "de-stressed" both drivers!
7) "Dynamat" the drivers!
This is the 2nd set of headphones as I still enjoy a lot my GS1000 (comfort & sound).
If I start to like it more then I will buy wooden cups (RS1 type)!
...a little experimenting. Made some slip-on cups for the first time. These are in Cherry:
Hey there- I've checked out this forum a number of times over the summer & decided to try to make some cups for my 80i's using this method:
http://headfonics.com/2011/07/grado-diy-how-to-get-a-perfect-woody/. Before I get started I thought I'd ask a couple of questions:
Are these, or any measurements/ dimensions "set in stone"- such as wall thickness or the diameter of the opening at the grille? Does the height of the cup make a difference?
Another thing that would be a great help is to know what is a "great sounding" wood to use? There is such an immense selection & I'm sure I'd be safe choosing mahogany or maple, but it would save a bit of energy if any of you could make a suggestion.
There is a lot of impressive & interesting work on this forum- thanks in advance for making all this info available to a novice.
Thanks, I'll start reading the thread. As for the drill press, I'll have to prove I'm not a complete klutz around tools before getting access.
*chuckle* I started with a drill press. It's safer than just a drill and hole saws. I have a reputation for hurting myself with tools, but a few months with the press and before I knew it I had a large and was using that instead...it's REALLY fun to make your own.
DIY or die
I plan to progress slowly with these cups (very attached to my fingers)- my very first job was for a furniture maker when I was 12/ 13. When I ruined over a dozen chair legs at the bandsaw I was "let go" & haven't touched a tool (for woodworking) since. Really liked being in the shop, though.
