post your grado mods....
KimblerHardkore
- Dec 27, 2014
SR125: Aesthetic modification, replaced rear grille, wired in stereo jack to left earcup for single-side removeable cable, modded comfies to expose driver grille.ok could you direct me a little on how to have this mod for my sr80e???
Wildcatsare1
Could somebody post a picture of your "Spacers" and how you install them? My apologies for the Noob question, I did a search of the Thread and couldn't find any.
020Assassin
- Nov 22, 2014
020Assassin
- Nov 22, 2014
Do you mean the distancers? You take a small amount of Blu-Tack (adhesive putty), put it on a flat surface and take another flat surface and roll it between those flat panes until you get a thin worm of putty that you fix to the rim of the distancer, then press the rim against the driver side of the headphone, so that you get an extra chamber in front of the 'speaker'. The ear pad gets attached to the distancer.
It's Bocote/Padouk
Do you like this one more than the walnut?
020Assassin
- Nov 22, 2014
Gr33nL34f
- Dec 5, 2011
one of you crafty guys should go in the distancer buisness with all these wood skills.
fleasbaby
Member of the Trade: Wabi Sabi Headphones
- Jul 8, 2011
LOL...I have a bunch of cups and sleeves that broke/didn't work out from when I first started experimenting that I think I held onto for just in case guys wanted distancers...if anyone is keen let me know dimensions and I'll see if I have something that will work...you can heave them for postage.
The part that's glued is stronger than the wood it's self.
rhead
- Jan 26, 2012
Does anyone have stl files for the gimbal? Want to 3d print alternatives for mine.
kopral 21
- Dec 21, 2012
Custom Cable silver+cooper for y magnum v4
020Assassin
- Nov 22, 2014
I hope you can send them off today.
I put a 125i in the cherry cups and compared them with a stock 125e. The cherry 125i had better attack and decay and soundstage than the stock 125e.
GREQ
This is not my mod, but it causes me so much pain to watch every step of this.
http://www.google.de/imgres?imgurl=http%3A%2F%2Fcdn.instructables.com%2FFT3%2F6J1I%2FGX10CHW1%2FFT36J1IGX10CHW1.LARGE.jpg&imgrefurl=http%3A%2F%2Fwww.instructables.com%2Fid%2FGrado-SR-325-Mod-using-the-Sennheiser-HD-570-headb%2Fstep3%2Fnull%2F&h=768&w=1024&tbnid=ruuIe57McJ7JwM%3A&zoom=1&docid=m9jWCDfJO_ZA7M&ei=ogzJVMPvFMf5ywPy-YLICQ&tbm=isch&iact=rc&uact=3&dur=1350&page=2&start=29&ndsp=35&ved=0CLIBEK0DMC0
kramer5150
- Sep 20, 2004
Yikes... how NOT to do a SennGrado mod. Hardly seems worth the effort. I've never had a Grado headband issue that the DT770 cushion couldn't solve.
Total: 7 (members: 0, guests: 7)
