BoilermakerFan
- Jan 2, 2008
Nice little 20W RMS into 8R, 25W RMS into 4R, peaks at 70W/90W.
I've found mine improved dramatically with some DeOxit in the pots, selector switches, Jacks, etc.
Sachu, did you use DeOxit in your headphone jacks? You might have a failing resistor on your jack's resistor network, unless both jacks sound bad to you, then I'd say you just need DeOxit in all the pots and especially the jacks. The headphone jack is just an internal resistor network off the output transistors. Try going direct across the speaker outputs and see if it sounds the same to you on the cans. If it doesn't, the problem is the resistors or jacks... Reminds me, I need to order Takman resistors for my headphone board when I order a few more Rikens and BGs for other builds.
Originally Posted by ludoo /img/forum/go_quote.gif How are things going in ortho land? I have second hand news sometimes from Kabeer, and still hoard the odd Yamaha now and then. I just got this, delivered to my door from a nice seller who lives 500m from here I've been looking for a Yamaha CA-xxxx for some time, but there are few over here and they usually fetch a lot of money. So when I saw this nice CA-400 on ebay local I jumped on it, and so far it looks like it's 80€ well spent and I wil finallybe able to use a pair of speakers again. Any comments from the amp gurus? BTW for the photo-heads, I was too lazy to change the lens (had an 85mm/1.8 on) and turn on some lights. |
