BoilermakerFan
- Jan 2, 2008
No, they are VOCs and they will permeate normal dust type masks. You need a carbon canister respirator mask. Most of the gasses are forms of formaldehyde, chlorides, and urea compounds. A caveat of the carbon canisters is that once the seals are removed, they have a working life of about 12-24 hours. After that, the activated carbon is simply neutralized by trace compounds from the air, so plan well, and do all your cutting at one time.
Originally Posted by Sambones /img/forum/go_quote.gif would a simple mask protect you? That actually sounds like a good idea, assuming it doesn't kill you. |
