May 16, 2009 at 7:06 AM Post #10,531 of 27,306
Originally Posted by DefectiveAudioComponent /img/forum/go_quote.gif
I was eying that one, but I think it went very high for something that's most likely a T20 clone.
T20 ? i thought it was T50v2 clone...?!
then what's the diff to the other type of Grundig Ortho here ?
yes, i know the other one using PMB type of driver & fell off pleather pads...
May 16, 2009 at 7:23 AM Post #10,532 of 27,306
yes, i know the other using PMB type of driver...
We don't know for sure what driver the 223 has but there is another Fostex OEM that looks identical. That one is a T20 clone. It could still be a clone of some other Fostex. But if the impedance rating is correct (which it might not be), it could also be a T30 or a T10. But in fact, we do not know for sure that it's a Fostex clone at all (it's just very very likely).
The 224 is a completely different design, most likely made by PMB. The biggest problem with the 224 is that I've so far been unable to get both good deep bass and airy highs, compared to the Dual DK 720. The Dual is also a PMB clone, but with a different driver. I have been able to get good bass, but then guitars go dead (no air). I have also been able to get airy guitars, but then bass is weak (it's like this witht fabric pads, roll-off at 55 hz but nice highs - not nicer than the Dual though and the Dual also has the bass). I'm still working on the 224 though.
edit: Current mod that I made on the Grundig yesterday is promising, although it does not provide as strong bass as the Dual. I have to listen to it some more though.... I have made so many mods that at first sounded promising....
May 16, 2009 at 8:03 AM Post #10,533 of 27,306
What makes you think that?
DAC is correct in his answer, but it's 90% a T20 i'm sure, theres a v.v.small chance it's a new driver. But I highly doubt it's anything other than that....(still who knows, theres no guarantees)
May 16, 2009 at 8:25 AM Post #10,534 of 27,306
sorry my mistake then, i thought all Fostex OEM are base on T50v2...
i had crosscheck this post, now i'm sure i missread/misunderstanding about GDHS 223...so, any Ortho member here that had change to compare GDHS 224 to 223 ? maybe, DAC ? or Ortho "Kakashi" ninja ?
May 16, 2009 at 12:41 PM Post #10,536 of 27,306
Originally Posted by dBel84 /img/forum/go_quote.gif
F2D , do you think there is enough benefit to use an amp with the YHE50 over driving it directly. I know that the headroom of the amp will obviously improve things but the added bulk and noise of transit sort of negate this benefit for me - I don't have a portable but have been toying with building myself another one. ( or just making the time to complete the one I started
) ..dB
YHE-50 does not benefit from it too much, basically more dynamic sound and better bass. But I use it with T20 and T50RP and I can't drive them from any of my DAPs properly. It's also more for the office than subway, as I use my ER4 in the subway most of the time.
May 16, 2009 at 1:23 PM Post #10,537 of 27,306
so who's the one grab this one ?
B&O KOPFHÖRER 70ziger Jahre KULT bei eBay.de: (endet 16.05.09 10:48:13 MESZ)
i just found that listing, suddenly it's end...
The U70 is very common, but Wualta and Kaaber tried it and didn't like it much. It usually is kind of expensive too. Also, usually, the pleather is gone so it is important to see that side of the can. I've recently seen one that still had the pleather on.
May 16, 2009 at 5:17 PM Post #10,539 of 27,306
i c, then U70 wont get much love here...from Grundig gdhs 224, Dual DK 720, HOK80v2, Yamaha HP50S, YHD2 of yours, which one are your most fave Ortho, DAC ?
Right now, it's the Dual DK 720
It has good bass, sparkly airy highs and of course fine ortho mids. Second, I'd put the YHD-2 because it sounds great and is portable.
By the way, if I count correctly, there are now 77 orthos in the list (when I count the orthos in my 120-page PDF file). Not counting stereo/mono variations. Perhaps I should post the list?
May 16, 2009 at 6:01 PM Post #10,540 of 27,306
There is a list of other othos on the wiki, plus all the orthos from brands like Yamaha, Fostex etc. All together there are 92 articles about ortho dynamic headphones on the wiki. If you got more models feel free to add them to the wiki.
A
* Aiwa HP-500
* Akai ASE-40-J
* Akai ASE-50
* Audio-Technica ATH-1
* Audio-Technica ATH-2
B
* Bang & Olufsen U70
C
* Canton KE-600
D
* Diango AUH-15
* Dual DK-220
* Dual DK-330
* Dual DK-720
* Dual DK-830
E
* ELEGA FR-901C
* ELEGA FR-902C
* ELEGA FR-907C
* Elektronica TDS-5 / TDS-5M
F
* Fostex T10
* Fostex T20
* Fostex T20RP v2
* Fostex T20RPmkII
* Fostex T30
* Fostex T40RP
* Fostex T40RPmkII
* Fostex T50
* Fostex T50 v2
* Fostex T50RP
G
* Goodmans OHP-10
* Grundig GDHS 223
* Grundig GDHS-223
* Grundig GDHS-224
H
* Heco PHI 300
K
* Kenwood KH-72
* Kenwood KH-83
* Kenwood KH-85B
* Kenwood KH-85W
* Kenwood KH-92
L
* Lafayette RP-50
* Leak 3000 Isodynamic
M
* Maior RPT-50
N
* NAD RP18
P
* PMB 6
* PMB 8
* PMB100
* PWB Dyna-X
* Pacific Stereo Concept CE-H
R
* RFT HOK 80
* RFT HOK 80-2
* Realistic Pro-30
S
* Saba H 30
* Saba Professional 90
* Sansui SS-100
* Sawafuji SF-1
* Sawafuji SF-16
* Sawafuji SF-17
* Sawafuji SF-7ST
T
* Tandberg TH18
* Technics EAH-810
* Technics EAH-820
* Technics EAH-830
* Telefunken TH-700
V
* Victor HP-D90
W
* Wharfedale ID1 Isodynamic
* Wharfedale ID2 Isodynamic
Y
* Yamaha HP-1
* Yamaha HP-1000
* Yamaha HP-2
* Yamaha HP-3
* Yamaha HP-50
* Yamaha HP-50A
* Yamaha HP-50S
* Yamaha YH-1
* Yamaha YH-100
* Yamaha YH-1000
* Yamaha YH-2
* Yamaha YH-3
* Yamaha YH-5M
* Yamaha YHD-1
* Yamaha YHD-2
* Yamaha YHD-3
* Yamaha YHE-50A
* Yamaha YHE-50S
There are a few Russian models missing. I need to add them to the list.
May 16, 2009 at 6:56 PM Post #10,544 of 27,306
I think that the wiki is complete :-)
Nuh-uh, i'm convinced there are some more hidden ones out there.
Plus there's a LOT of work needed to fill up each headphones page with info, most are empty. Please if anyone has correct info come and fill in the wiki.
There's still a lot of info from this thread thats not on the wiki.
Also I know we can add a modifications guide to each headphone's article, but I think you should create a modification article as well F2d, to put out the general theories we have found in modding orthos.
