Originally Posted by Serge44
My Yamaha HP-3 has very small amount of bass.
Aha! then mine must be a
Russian HP-3! This explains everything!
I wish it did..
F2D: Go back to the very first few posts in this thread. Planars have one advantage which is in one respect a disadvantage: there are no brakes. Let me explain... [sfx: running boots, screams] Okay, for those who are left, let me explain..
Ever used a triple beam balance? It uses a magnetic damper to stop the beam's oscillations. The magnet induces eddy currents in the moving beam which in turn create a backwards magnetic field which fights against the magnet's field. It's called
Lenz's Law. Dynamic drivers have it, planar-magnetics don't. As a kind of poetic compensation, planars get the wholly-resistive impedance you've heard us going on about. The two phenomena are tightly linked. Stronger magnets don't help transient response in a planar, but has a very noticeable difference for woofers in particular and, to a lesser extent, headphone drivers.
Electrostats don't have brakes either. Look out! [sfx: long squealing skid, crash], but they have a diaphragm whose mass is in the same ballpark as that of the air surrounding it, which is why Stax tried for the thinnest diaphragm material possible in the 1987 Lambda Signature.... and then backed off, because they'd passed the point of diminishing returns in the Lambda enclosure.
You can damp a dynamic phone by simply giving it an intense magnetic field with minimal losses and whose strength is constant throughout the voice coil's excursion. This is harder than it sounds, which is why better dynamic headphones cost more. Their magnetic circuits are more carefully engineered.
It's kind of an advantage, being able to change a design parameter that doesn't throw off everything else..
