Noloben
- Jun 22, 2016
A very nice recable job there also.
Thank you, but these are just $2 silver plated from ali. Though, I saved plastic things near earcups from original cable.
Nick, thanks for the heads up on the variation. I'll keep it in mind. Yes, I do have the DynaX still. I was looking around for some possible ear-pads in my very slow way. Picked up some generic Denon D2000 pads that I though would fit, but they don't quite make it. The housing is from a Stax SR5 mold so something might be around that works better, you might know - or I can just find some two sided tape and make it work. A good reminder that those are in a box and waiting for some attention. I've not been looking but I've not seen another one show up in the wild since I first picked up my pair.
Yeah but it looks much better than stock.
Is there a particular Russian forum you like better than others for information?
Just wondering if there is one I am not aware of.
I tend to go read them and catch up every few months.
Not seen much new on the MyST items lately, seems mostly posts on Mycroft forum.
Are you considering simple / easy to remove mods to them at all?
I found the YHD-1 to be particularly tricky.
In fact I just revisited it the other night and seemed to have nailed it down a bit more, enough that I can ignore it and simply enjoy now instead of thinking about tweaks.
Maybe a recable here is the next thing
Shape of the Y splitter mostly IIRC.Nad RP18. Is there a way to determine the variant (Kapton or Mylar) without removing the pads?
Hi,
I just received a pair of Nad RP18. Is there a way to determine the variant (Kapton or Mylar) without removing the pads?
What are basic mods (pad swapping ?) you would recommend for these ? My ears are quite crushed against the stock flat vinyl pads.
Thanks
It's a feature.I max out the headband adjustment
How you attach pads makes big difference to overal sound.I just wanted to drop in and thank everyone for all the info in this thread.
I took the plunge and modded my Yamaha YH-3 since I had everything laying around to do it.
Did a layer of round cotton pad, a layer of felt above that then popped on some fenstrated PU leather pads for Grados and wow these sound so great now! It's a night and day difference. Clear highs without being sibilent and much more tight and controlled lows. Mid-range is smooth but slightly recessed moving these into a more U shape sound profile than I'd have expected possible from the original sound. Soundstage is exceptional as well. I'm well pleased.
My biggest issue is comfort ; stock on-ear pads are awful so I replaced them with some Chinese Ori pads found on Aliexpress last year. Major improvement in treble and overall clarity. But now with thick pads, I max out the headband adjustement - first time it happens, and my head is not large.
Hi everyone, player.ru user sacd provided some pictures of popular (mostly in Russia) 55mm ortho drivers. He said he doesn't mind if I post it here, so here you are
