WallofHooligans
- Feb 8, 2017
Where can I buy a window tint for my sennheisers?
Yeah some of em have a bit of glue, hopefully the clips didn't break when you pulled them apart though!
Are you going to transplant them into another housing?
******** HMMMM I just tapped the edges over a piece of black foam and yeah there was some tiny amount of particulates, very small stuff so Unsure if I want to handle this stuff too much. I might skip it.
Since the Audiotronic AHP66 is essentially part of the same family of drivers but with TWO magnets instead of one, I do remember playing around with this idea and tried some configurations.My Victor hp-d70 has the singular magnet earside. I wonder what flipping it over would sound like, but I couldn't do it without risking them. Too fragile. As far as I can tell, listening through the other side probably yields a cleaner sound but at what cost? I don't know.
You only have to be somewhat careful when putting it back in that the holes are correctly aligned with the front magnet.
But this is relatively easy with a strong light shining through and a little patience.
Yeah, I think the cheapest offer is a 24"(60.96 cm) x 12" (30.48 cm) sheet for 17.25 USD. Doesn't sound like a lot of dynamat though, but I guess will last a bit for headphones.
Would you guys recommend putting some dynamat in this earcup here? From an Aiwa HP-30.
Feilong, do you know the rough inside measurements of those Aiwa ?
I am trying to figure out a shell for the large rectangular 80+mm TDS-7 drivers.
Pictures are very deceiving and I don't wish to randomly waste $ buying older things that may not fit them.
also you know you have too much time on your hands when:
Yeah i counted the holes in the pictures above of the two driver sets...
Yamaha = 36 holes
TDS = 57 holes
