- Aug 25, 2013
Just buy Alpha Pads. They're amazing for $60 + shipping.
For some reason i had it in my head the alpha pads were double that price, just placed my order.
I wouldn't mind using a super-thin bonded leather, but I guess they just don't make them thin enough.
Are they improving any? the pads?
I wonder if they still sell the old version as well as the new ones. Any idea?
Twaron Angel Hair: people are too cheap to bother maybe? Yet it is ridiculous amounts.
Update on the T10 - If you've got a T10 you HAVE to try out these ear pads. I've been listening all day with these, and for the first time they don't do ANYTHING really wrong.
Just to put this into perspective: I'm not using a treble reflection card, and I've got treble, bitey mids (nice twangy guitar sounds), and more width in soundstage.
If you don't like a tiny bit of boom in your bass, then give this a miss.
If you want to hear your T10 with both plenty of bass and some treble (treble is certainly still south of 'neutral' by Senn/AKG/Beyer/Hifiman flagship standards) and 'NO' (significant) mid-bass hump, absolutely give this a go.
For the first time instead of just throwing around some ideas I can almost guarantee you won't be disappointed. Comfort is also improved.
Mods:
• 1mm thick creatology felt directly on rear of the driver - 18mm diameter circle
• thick (3mm?) sticky back creatology felt around circumference edge of cup
• all vents, bar the outer-most 2 closed with electrical tape (or whatever tape)
• roughly 20mm diameter circle of thin felt stuck to the back of the cup
• 1 layer of full-cup-size disc of arctic cotton in the cup
• hd205 pads stuck on with double sided tape
Is the 1 mm thick, 18 mm disk of creatology felt limp or stiffened?
So here's something you don't see every day.
The guts of a PMB 8.
No headphones were harmed in the making of these photos
I was able to successfully open both cups without making any (major) damage (a few tiny scratches).
I replaced the disintegrating foam.
I guess there isn't much room for modding, but to be honest, they're already really quite good without any..... ok... maybe a little.... like new ear pads.... and arctic cotton instead of foam.
Heh, it took a while for the Hifiman and Audeze ppl to find out that there's nothing comfier than a Bellini headband: http://www.head-fi.org/t/738025/new-audeze-prototype-z#post_10953629
Actually there is, an auto-adjusting Bellini(à la cd3k) hopefully they'll figure that out later as it looks like it's all about baby steps
Are the vents damped with felt like Yamahas?
Thanks for the pix!
