leeperry
Galvanically isolated his brain
- Apr 23, 2004
the sansui is a beauty but it's got zero bass FWIR, can you confirm?
Is the TDS-17 a portable orthodynamic? Do correct me if I'm wrong.
If it is its the best kept secret ever since they only cost $15 on ebay...
http://wiki.faust3d.com/wiki/index.php?title=USSR_Headphone_Clone_Chart&printable=yes
Its dynamic driver.
Originally Posted by szerecsen /img/forum/go_quote.gif
OTL C3M tube headamp
I disagree about the ss-100 not having bass. Its certainly not a bass head's phone but it is there and pretty well defined. For example, the bass drum that plays every measure in Stravinsky's rite of spring sounds deep and prety accurate. There is also that slam present that gives you goose bumps. I also really enjoy using the sansui whenever I listen to bass heavy jazz(mingus and others). It has better bass than the yhd-2 and dr-z6, however, it may be a hair less detailed than the Dr-z6 but it is more present and hits harder. I also preferred the sansui to my hd650 when I had the 650. The 650 was much more comfortable though. These, however, are just my impressions.
I agree.
As with all vintage headphones, variable aging effects and how they were stored over the past 20 to 30 years likely results in sound quality differences from one set to the next. The set of SS-100 I'm listening to sounds very good. The bass is accurate and fast, just not as pronounced as some other vintage TOTL orthos. Then, there is "the look" and build to consider... Sansui SS-100 may well be the most beautiful headphone I've ever seen, as well as light weight and comfortable for "on ear" 'phones.
If the (mylar) RP18 is any indicator (which it should be given the nature of the SS-100 transducer) then the bass, while not lacking, is rather overshadowed by the upper regions, at least in stock form. The RP18 also has some NASTY distortion up top; not sure if that was my amp, lack of mods, or the transducer, but it was there and is the reason why I sold it. My hope is the SS-100 lacks this issue due to the heavily dampened enclosure... if I can ever get my mitts on one that is.
So, BMF, is there perhaps any news regarding that GS-X-II you're supposed to be getting? I think you know why I'm asking.![]()
It is a quilt batting material, there is A.Cotton ( 80% Cotton-20% Polyester ) and an A. Bamboo version (50% Natural Bamboo 50% Cotton) , basically a fuzzier felt type material, around the same thickness as felt. A.Bamboo is a little more transparent and slightly thinner, A.Cotton is slightly thicker and fuzzier.
They are my go-to in one form or another between the two of them usually things work out well, and of course in combination with other things often.
http://quiltparadise.ca/products/index.php?Category=Battings
http://store.hamelsfabrics.com/stores_app/Browse_dept_items.asp?Shopper_id=9719329333379719&Store_id=360&Page_id=17&categ_id=6118&parent_ids=0,87&name=Quilt+Batting+-+Arctic+Batting
The first link is the safest and cheapest i would guess ( hard to find decent links! )
If it is a real pain in the butt to source out PM me and I can send a bunch out to you on me since it is relatively cheap and i get it by the metre/yard. Same two types as have been used in here to decent result.
I will make a point of going out tomorrow and getting another yard or two of each to ensure I have enough for a lifetime of mods.
It was part of one of the crucial keys in the main Memory Foam Mod T50rp damping recently posted in the Incremental Mods Thread
By the way have you ever opened the TDS-7, it scares me. I have seen it open in pictures before and can tell where the tabs are but doing it is another intimidating factor, definitely need opening and tweaking, but I don't wish to botch it up! I can usually get into most things including trouble
Thanks for explanation on A Bamboo. Wood need to see if I can find something here in europe.
I haven't opened any Amfiton yet. I was going to ask BMF if TDS-7 drivers could be transplanted to Takstar?
This weekend I got another ortho Universum
