Apr 3, 2013 at 9:52 PM Post #21,379 of 27,319
Definately worth the price
shame i like the retro look too much, or i would mod them to pieces. It would be cool to recable those with 3.5mm jack. Would make kickass retro portables...even though naturally quite power hungry. Less than fostex t20...somewhere around hd600 id say. Without being restricted on simple damping mods, those could be some really extraordinary headphones. Nonetheless these headphones made me a believer on orto technology. Nicely narrows my next upgrade between hifiman and audeze
Do the mods, you might just find that the Himans or Aud's are not really an upgrade at all;)
Apr 3, 2013 at 11:29 PM Post #21,381 of 27,319
Quite enjoy the convolved HOK now. Big step up from what conventional modding could do - though it has to be said that the digital bass boost needed for the HOK to reach the level of my bass-lite HP-50 does distort at higher levels around 100 Hz or so. Still, quite good for lower-volume listening.
No idea why the convolution from one phone to another worked so well here but has failed with some other phones. For sure the channel balance convolution works almost perfectly, so it may have something to do with similarities in pad and baffle-ear chamber dimensions between the target and source. Investigations ongoing, and, as always, carried deep into the morning hours.
Apr 4, 2013 at 2:20 AM Post #21,382 of 27,319
Listening to my new'ish yamaha YH-3 and I'm digging the sound but I'm just not the basshead i used to be. won't pass judgment until i have used them for a few more months. Any suggestions for replacement pads? They are worn and I'm sure that's affecting the seal to my ear. I might try to find a new home for them and nice new pads would be a big plus.
Also does anyone know of a good product to clean headphones? I have a growing collection of audio gear and some of the used stuff i get can be outright filthy. Armorall works but i dislike the oily feel and smell it leaves.
Edited to better reflect my thoughts.
Apr 4, 2013 at 7:40 AM Post #21,383 of 27,319
Listening to my new (vary used) yamaha YH-3 and I'm digging the bass but not much else, won't pass judgment until i have used them for a few weeks. Any suggestions for replacement pads? They are worn pretty bad and I'm sure that's affecting the seal to my ear.
You are aware that the general recommendation with those phones is to mod them inside the cups? Though usually the modding aims at reducing bloated bass, so if you prefer the bass as it is, that sort of modding may not be needed.
Someone recommended the Sony V150 pads, but I've not tried them. The Sennheiser HD 25 pads might do as well, but I've not tried them either.
Apr 4, 2013 at 9:05 AM Post #21,386 of 27,319
Since you edited your post, let me rephrase my response as well.
Put felt into the cups. It flattens out the bass response. Instructions for this are throughout the thread, it's a staple mod.
Oh, and I see you're already selling them. I hope $95 wasn't what you paid, and if it was, you probably won't manage to get it back. Should perhaps mod them and see what they can do for you.
Apr 4, 2013 at 2:11 PM Post #21,387 of 27,319
Final pics of the Hosiden DH-80-S.
This is what it looks like with the chrome ring removed. Lid screwed down, and ring in place, it's virtually a closed design.
Original damping was a piece of whitw felt and foam. The foam had disintegrated so I replaced it with two new layers. Originally the Hosiden sounded dull and honky. Did not improve much fully open. I tried a small reflex dot for treble extension and the damping on the picture and the sound became quite nice. The let-down are the pads - vinyl and with a loose fit. Some quick experiments with HP50 pads that was lying around indicated that the right pads could make this a quite enjoyable headphone.
khbaur has an Audio Technica driver that is 150 ohm in his rare ATH-M2 I think it was called. It's posted up in here. The only 150 one i have heard of in that style is the ATH, well also the HP-50 type but that doesn't have the housing ring around the outside does it ? ( don't think so but I forget ATM ).
Link up here.
Can you feel how many holes there are underneath the damping there? Or shine an LED flashlight through . It would narrow it down.
Here's the photo you requested. 1 + 8 + 8 = 17 holes, all aligned.
And the size of the driver.
Thanks for your attention.
Apr 4, 2013 at 3:24 PM Post #21,388 of 27,319
That does not look like our normal SFI driver. Your driver is too large (50mm) and it has too many holes.
Compare to this: http://wiki.faust3d.com/wiki/index.php?title=Image:Eaglepartsbaffledriver.jpg
Apr 4, 2013 at 9:35 PM Post #21,389 of 27,319
Don't know if any of you were wondering, but even though the ATH-M2 is also 150 Ohms it has the "standard" 37mm, 9-hole, SFI driver and is part-swappable with the ATH-2.
Apr 4, 2013 at 9:59 PM Post #21,390 of 27,319
^ really I thought they were bigger for some reason , so that rules them out.
Anybody else got any ideas that can pin these down for OEM, these look like they would pump quite nicely given the size of those holes.
