Oppo HA-1 Impressions Thread
post-10704432
Post #1,051 of 5,289
kawaivpc1
How would you guys compare Oppo's HA1 to Yulong's DA8? or Astell n Kern's AK240??
Is HA1 sounds significantly better than AK240, DA8 and Calyx Femto?
post-10704459
Post #1,052 of 5,289
poo
I understand the Oppo has pre outs which can be used to drive a power amp. I have an integrated amp and previously used the RCA audio outputs on my Benchmark DAC1 to feed the amp a signal from the DAC. Can I do the same from the Oppo? Just send out from the DAC to my integrated amp?
post-10704461
Post #1,053 of 5,289
Yes. You can connect the HA-1 direct to a powered amplifier or powered speakers then use the HA-1 to adjust the amplified volume.
post-10704491
Post #1,054 of 5,289
mrscotchguy
Can anyone who owns this answer a function question about the Theater Bypass Mode? Does this function work for each output (ie one for xlr and one for rca?) or a toggle that is a blanket for all outputs?
Oh, and is it tough to access theater bypass in the menu?
post-10704525
Post #1,055 of 5,289
Each input can be set independently of each other as Home Theater Bypass. Home Theater Bypass will be enabled for both outputs when engaged. It is very easy to engage. Just select the source you want to use in Home Theater Bypass using the jog dial. Press the SOURCE button until you see Home Theater Bypass appear on the front of the HA-1. Use the jog dial to select BYPASS then the SOURCE button again. At the next screen select CONFIRM with the jog dial then press the SOURCE button again.
post-10704542
Post #1,056 of 5,289
mrscotchguy
Thank you for the incredibly fast response, Hastur!
I normally wouldn't ask, but looks like I won't be getting my HA-1 due to some sketchy issues with our former landlord. Guess I will be living vicariously through everyone here...
post-10704569
Post #1,057 of 5,289
We will not be going anywhere, so the HA-1 will always be waiting for you. And if anything, we will have refurbished products you can buy from us in the future. We generally sell refurbished product 8 to 10 months after the initial release of the product, so check back next Spring for a discount.
post-10704593
Post #1,058 of 5,289
poo
I guess what I'm really after is a DAC out so I can use the volume control on my integrated amp, which only has RCA in.
post-10704606
Post #1,059 of 5,289
You can use the player in Home Theater Bypass so the volume controls on the player are not active on the RCA/XLR outputs, and use the volume controls on the integrated amplifier.
Reactions: poo
post-10704617
Post #1,060 of 5,289
MattTCG
I want to buy this amp in the worst way. Must find some semblance of self control
post-10704674
Post #1,061 of 5,289
poo
lol yeah it's a bit like that isn't it :)
post-10704692
Post #1,062 of 5,289
JML
Forget self-control.  I'm thinking about getting a pair of Adam Audio A3x or A5x active speakers to mount on the wall, and an Adam sub...
post-10707959
Post #1,063 of 5,289
topgunsphd
What kind of difference will the hd800, alpha dog, and he500 have going from se to balanced with the ha1?
post-10707973
Post #1,064 of 5,289
vigotone
Just settling in with my new HA-1 and Audeze LCD-XC cans. Quick question: should I do High Gain and keep the volume dial low, or Standard Gain and crank the volume? I would think High Gain, but the manual says the opposite!
post-10707975
Post #1,065 of 5,289
x RELIC x
The West Coast, Canada
Read this post
A basic explanation of what to expect from balanced output.
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
