Oppo HA-1 Impressions Thread
post-10703265
Post #1,036 of 5,289
jonstatt
Test OPPO HA-1: Reference HDfever award for extraordinary DAC!
Tracks and measures in Nico >>
Here is a marathon review of the HA-1 by Nicolas Bécuwe of HDFever on July 10, 2014.    No doubt this is the most diverse technically/image laden review you will have the pleasure of viewing.
source
Very interesting indeed. Although they missed the one detail I wanted to know which was the type of opamp used. They mentioned they exist for all of the outputs, but despite mentioning very specifically the components used elsewhere like brands of capacitors and transistors...they didn't mention this which was a very odd omission.
post-10703268
Post #1,037 of 5,289
Smarty-pants
^ Yep, the HA-1 is not meant to be used as a media player.
The asynchronous USB and MOBILE USB inputs are already incredible features as-is.
A great combo would be to pair it with something like the uber popular Oppo BDP-103 or BDP-103D for your source playback from USB drives and discs.
However if you can store all your stuff on pc/mac and/or IOS/mobile devices, then you can get it all from the HA-1 alone.
post-10703296
Post #1,038 of 5,289
sbgunn
  We use op-amps, but the manufacturer and model numbers are not available at the top of my head. For the BDP-95 and the BDP-105 we used Texas Instruments LM4562/LME49720 op-amps, so it is very likely that we are using similar chips in the HA-1.
^ mentioned earlier in the thread.
post-10703303
Post #1,039 of 5,289
jonstatt
  ^ for the person who was asking about opamps
Many thanks with the only minor exception that HasturTheYellow said "it is very likely we are using similar chips"...which basically means he wasn't 100% sure. But thank you...at least it gives me something to go on :)
Just to add that LM4562 and LME49720 are the same thing and is a highly regarded op-amp....audiophile level just below doing it discretely without op-amps at all.
post-10703332
Post #1,040 of 5,289
mikeyatswb
TH 900s work just fine with HA-1, no problems with noise floor, distortion, etc.  Volume does ramp up quickly, leave it on low gain.
I have the Fostex th600 here, which I believe is a more (or similar) demanding test...
Specs:
Impedance: 25ohm
Sensitivity: 94dB mW
Maximum Input: 1,800 mW
At high gain on the HA-1 upon reaching the halfway on the volume (about-13db)
It is already at ear bleed loudness levels that I cannot tolerate for long.
This is the 1/8 headphone out, not the balanced xlr. .
Now I pause the music on foobar2k and turn volume to maximum to see what I hear.. .
Listening. .
Straining..
Nothing. .
Not the slightest tiny bit of sound.
Zero "low level" noise detected. .
Thanks for the feedback on this.  The following review was also very complimentary: http://headfonics.com/2014/07/the-ha-1-headphone-dacamp-by-oppo/2/
"The Lawton Denon D7000 also paired incredibly well with the HA-1, these are two headphones never to skip over if you own the HA-1" (the other headphone referred to being the PM-1).
To the extent that the D7000 and TH-900 are similar, I would think this opinion carries over to the Fostex.  FYI, this review is also very interesting in its (qualitative) comparison of the DAC implementation on the HA-1 and Burson Conductor, another amp/DAC I considered.  I'm going with the HA-1: it's got everything I want, nothing I don't want, it's considerably less expensive, and---a big bonus for me---it has a remote.  I seem to be in the minority, but I really like a remote with a head amp, which really limits the options.
post-10703442
Post #1,041 of 5,289
preproman
I wouldn't call asynchronous USB an "incredible" feature, it's pretty standard now a days.  The Mobile USB is useless to non Apple users..  Just saying..
Reactions: bfreedma
post-10703510
Post #1,042 of 5,289
hikinokie
Ok Smarty-britches, If I'd have KNOWN Oppo was building this kick-ass HA, I WOULD have bought the 103 instead of the 105.
But NO!!!! these things must be kept under wraps don't they!!
post-10703878
Post #1,043 of 5,289
Raptor34
Yup, that's what I have.    Two source components and the HA-1.  Nice
post-10703965
Post #1,044 of 5,289
HiFiAudio
Just to give a bit of perspective of the timeline involved with your comment.
BDP-103 released 10-03-2012, BDP-105 11-16-2012 (approx dates)
How do you expect Oppo to let you know about the HA-1 so far in advance when it was first mentioned online Aug 18th, 2013 only as a prototype, and finally available after official launch April 11th this year, shipped a few days later.  Yes it was under development for some time.
post-10704057
Post #1,045 of 5,289
Smarty-pants
It's still a nice feature. I didn't mean it was ground breaking or anything, but it adds to the overall list of high quality features of the unit.
As far as listening to external sources through the HA-1, they've covered all the bases that an audio-only unit needs.
The mobile input can also be used with the proper Android devices with an adapter... or you could just buy an iPod.
post-10704369
Post #1,046 of 5,289
They are not the same, which is why I said the are likely similar. We have always used TI OP/AMPs, so it is a matter of which ones we used for the HA-1. I have the day off, but I will try to get the actual OP/AMP information for you on Monday. Unless I forget.
post-10704371
Post #1,047 of 5,289
poo
Will the Sennheiser balanced cable for the HD800 work with the Oppo?
post-10704390
Post #1,049 of 5,289
poo
Thankyou, now go enjoy your day off! :wink:
post-10704413
Post #1,050 of 5,289
Xyrium
Now that's dedicated support, and one of the reasons I purchase products from OPPO!
