scootsit
- Oct 23, 2011
For me? No. I couldn't get the 8320 to fit, period. The left one made my ear feel like it was going to fall off, it hurt so bad. The bodies of the 8320 are huge, absolutely massive. I was able to get the 8320 to fit great a few times, and the sound was truly awesome - but I ended up getting rid of them because they just hurt too much. I ended up going with the VSONICs, even the GR99, which is a bit less analytical and is a bit bassier is a step up from the 8320 in my mind, because I can actually listen to the music, and stop focusing on the pain.
Quote:The sony hybrids fit the Monoprice just fine. They're a tad small, and it takes a bit of work to get them on, but they fit very snugly.
Thanks for the reply, then I'll probarly be buying the Monoprice 8320 and the Sony hybrids, and if I'm not satisfied with them (probarly comfort wise) I'll buy the CW31
Have you tried the monoprice 8320 with the sony hybrids? Could you comment on how they fit and if they are comfortable?
