average_joe
- Dec 5, 2008
Congrats on review #200 in this thread...and let's not forget the 94 portable headphone reviews. Impressive!
Nice RE272 review, it sounds like a very interesting product specially since I've been leaning towards that kind of sound.
The RE262's ratings on comfort and isolation should be updated though since they're pretty much the same in these regards because the 262s use the same modular configuration. Even the build of the cable may be the same...
Hifiman seems pretty conservative on showing off it's specs. They rarely market the fact that the 9mm driver uses a titanium coated diaphragm or that their cable is OFC (though i'm not certain on the latter).
Anyways, congrats on reaching 200 and I hope you don't reach 300 anytime soon for your sake.....
Hey joker, I owned a pair of Brainwavz M2s and enjoyed them thoroughly. I am currently looking to buy a new pair of IEMs. I wouldn't mind venturing from its sound but would like something similar to it. What is your opinion in regards to PR401s, CC51, and Xcape IE with this in mind? Genres I listen to are Hip Hop, R&B, Jazz, Alternative & Indie Rock.
Very different signatures... the UE500 is a bit V-shaped in response, more of an ECCI PR401 or MEElec CC51 sound. Not quite as good as those two but close and a good deal at $55, though you can find the CC51 around that price if you're in the US. I'm not thrilled with the build quality of the UE500 but it's passable. Very lightweight and comfy, too.
The M2 will be warmer, have more pronounced bass and a significantly more forward midrange, and smoother, more laid-back treble.
Yes, I've only used two of those and they both have more upfront vocals than the E10. You might even like the E30 better than the E10, or the Brainwavz M2. Even the MEE CC51 is less mid-recessed than the E10 and has better clarity and detail overall. If you could say what you like and what you'd like improved about the XE200 and TD-III that might help narrow it down.
If I may, he mentioned at the very end that "the balanced score would be one or two tenths higher," making it just about even with the EX1000's own rating of 9.4.![]()
Would you put RE272 in balanced mode ahead of EX-1000?
Thanks for your answer, is there something similar to the brainwavz m2 signature for a similar price?, I see the Xears resonance, they have the same note in sound(7.2) but perhaps they are a different signature of sound. I think that I want for something a bit more clear than the M2.Regards.
My question still remains the same. I was not asking about SQ scores alone. There are a few IEMs with the same score, but Joker would probably take W4 over SM3.So,![]()
You finally reached 200 iems for this review thread and that is quite the featIt seems like they finally came out with a upgrade over the RE0 with the RE272 which is great although I've never been a fan of their cable so hopefully this one is better.
With the PR401 in mind, is there another IEM out there that is not so pushed back in the mids? I'm not sure if I'm describing it correctly, but it feels as if there's a hollowness to the sound which could be from the V-shaped frequency, thus higher energy frequencies stick out to the ear more.
@Joker
Hi and many many congratulations to u on the review of 200th IEMI'm luking for an IEM with a sound signature like this: Need an IEM which has bass quantity like M2 but with much better quality, timing and speed, a tad more treble with smoothness than M2 with an excellent imaging, layering and instrumental separation and twice or thrice better soundstage than M2. Mids should not be recessed also not the center image of the sound signature like M2. Please suggest me the iem based on the sound signature I'm luking for. Thank you.
Budget is around $100. Thank You.
Congratz on the 200th iem review @ljokerl!!! Hopefully we still have new top-tier iems coming for review.
