Jul 19, 2013 at 7:06 AM Post #3,227 of 4,841
So does Sensaphonics. But both companies make a hole in the silicone shell and, from the feedback I read, changing the cable becomes a delicate operation you don't want to repeat too often.
Wow, nice hint Sinocelt, thank you. I will keep it in my mind and not to play with cable unless it is really necesarry.
Jul 19, 2013 at 8:58 AM Post #3,228 of 4,841
I don't know - the Sensaphonics solution seems pretty robust. It's basically like the Shure connection, that snaps in place with a confidence-inspiring <click!>, but the contact point is buried inside the silicone. The shell makes a tight seal around the cable as it inserts, and the whole things feels like it could be done many times (barring any buffoonery of course).
Jul 19, 2013 at 9:14 AM Post #3,229 of 4,841
  <click!>
Click with an exclamation mark, no less!
Jul 19, 2013 at 10:05 AM Post #3,230 of 4,841
Sensaphonics does, in fact, use the same type connector (coaxial) as Shure on the cable for our 3MAX, 2MAX and 2X-S models. It provides a secure connection, yet can be fully rotated. Our cable is slightly different in length and stiffness (vs. Shure) and incorporates a strain relief collar clip. The goal was to have a connection that is both very secure (no accidental disconnects) yet easily field replaceable.
Our customer base is roughly 90% touring musicians and audio techs, and trust me, they would not accept anything less than a robust, reliable solution for life on the road.
Jul 19, 2013 at 11:26 AM Post #3,231 of 4,841
I believe it. While not quite as flexible as the typical braided cables used by most other brands, the Sensaphonics cable has got to be the most durable of any CIEM I've experienced.
Jul 19, 2013 at 11:56 AM Post #3,232 of 4,841
  1. I made a mistake: It wasn't Sensaphonics I was thinking about, but ACS. Sorry, I should have checked (as I just did) rather than trust my memory.
  2. Your connector has changed since I last visited your (Sensaphonics's) website. Last time I had a look, the connector was outside, on the faceplate, and rectangular. (If I can trust my memory, this time!)
Jul 19, 2013 at 1:17 PM Post #3,233 of 4,841
That's correct, Sinocelt. Formerly, a small acrylic block held the leads, and was held in place by a nylon screw. Very reliable, but a bit of a pain to replace in a poorly lit backstage area. We still use this type of connector on the 3D Active Ambient (which would require a quadaxial connector to carry the ambient mic info along with the monitor feed).
After considerable testing, we went to coaxial cables for 3MAX, 2MAX, and 2X-S around February/March of 2012.
You are also correct that the ACS cable connectors are proprietary. I haven't experienced them.
Jul 20, 2013 at 2:18 AM Post #3,234 of 4,841
The pictures on your website are really small. The picture in this PDF (also from your website) is much clearer, for anyone here curious to have a look. For those who'd like to compare with ACS's solution, click here for high-resolution pictures, courtesy of average_joe.
Jul 20, 2013 at 8:15 AM Post #3,235 of 4,841
OK so it seems I'm cursed when it come to customs :)  Not the minervas which are still doing fine but one of my original reshells picture below :-
That's a shot of my infamous right ear, the one that's given me all the hassle.  In it more or less is a klipsch x10i reshelled.   Only it isn't!  Apparantly what it is is a dba02/b2 twfk clone of some description.  Below for everyone who understands these things is the graph that I had done :-
 So someone somewhere out there has a b2/dba2 reshell that's actually a klipsch!  Sorry about that if you happen to read this post :)  I'm not too upset as I have already had a refund over the various fit issues, but I'm still irritated that even if the fit had been sorted it wouldn't have been the same iem that I had sent in, coupled with the fact they went back at least 3 times to be sorted.
Jul 20, 2013 at 10:31 AM Post #3,236 of 4,841
Definitely seems like one of those freak accidents --- it's indeed hard to picture how they could screw it up so badly, especially when they used the original cable. Frankly, it's a bit baffling.
Unless, of course, they accidentally damaged the BA when soldering (it happens) and assumed you couldn't tell the difference between the two?
Jul 20, 2013 at 11:26 AM Post #3,238 of 4,841
Here are a couple photos of the Sensaphonics coaxial connector design. As you can see, it is embedded pretty deeply within the silicone. FYI, we also use an O-ring to provide added moisture resistance - pretty important for certain performers on stage.
Jul 20, 2013 at 11:37 AM Post #3,240 of 4,841
Out of curiosity, would it be safe to assume the coaxial connection doesn't too easily swivel,or more realistically flop around, like it does on Shure iems?
