- Mar 20, 2010
Exclusive mode will have lower latency, so less sound lag, though I can't tell (it's only about 1 1/2 frame difference, which is essentially instantaneous), so I use Shared when I can. Exclusive will take over whatever source you select, so if you set, say a G6 as the device for Redscape, you can't use the G6 as a normal sound device/without Redscape. It'll stay muted until you either select shared mode, or switch Redscape to another device.
In terms of sound latency, for comparison, Apt X low latency is over 40ms difference. Shared mode in Redscape is 25ms I believe. So less lag than even the low latency version if AptX.
