- Mar 20, 2010
I think you're overthinking it.
My Sansa Fuze dongle would connect to its Proprietary charging input, and the other end was 3.5mm, so line out. It doesn't matter if a DAP has more power than a phone. A line out is a line out. I think there's only so much power you need for line out.
Why do you want so many dac/amps in the chain? It can't be any more beneficial than just using an initial amp as a preamp. The conversion from analog to digital and back to analog would likely be even less ideal than just amp to another amp. There's still potential to put too much volume into the signal going back to digital, emphasizing whatever distortion the first amp introduced.
And yes, SXFI or any VSS survives any conversion once it's already been introduced into the chain. The VSS signal has already become the standard signal. No way to change it back.
