illram
- Nov 24, 2016
Just out of curiosity, is there anything that beats the X7 with a vastly expanded budget or is it pretty much the king of gaming atm in terms of VSS?
Define "vastly expanded"? You can't beat the Smyth A16. But it's $4,000...
Hi all, first of all I’d like to thank the OP for such an informative post. I’ve read through a lot of this thread over the past month and learnt a lot.
I recently purchased the G6 after reading all the positive comments regarding it's virtual surround. I'm not sure whether I have it setup correctly, with the below settings I can't hear footsteps in Modern Warfare as loud as I could using my Astro Mixamp TR on the PS4. I'm using the A40 headset but looking into some audiophile headphones next. I did try the AD700X but returned those cause they just didn't work for me compared to the A40/mixamp combo in this game. I lost count the amount of times people ran up to me without me hearing a peep. I tried running a flat EQ in the mixamp and used my older mixamp with similar results. Maybe the soundstage is too large and footsteps sound too far away/softer than I’m used to.
My G6 settings:
Equaliser is set to Gaming (I think this on by default cause I haven't changed it)
Dolby set to full? (the circle is all grey)
Surround on & set to 60 - I had it set to 100 to begin with but read some comments to lower it to 60 or below?
Crystalizer, bass, smart vol, dialog+ all off
Setup - Headphones - Output mode is audio effects & 7.1
At the bottom I see the below icons highlighted - headphone mode, gaming, SBX, dolby audio when my PS4 is on (it's connected via optical) and headphones.
Any help is appreciated. I love this device so far, it sounds a little different than the mixamp which I like. Things sound clearer and I think the positional audio is a lot better as well. Only issue I'm finding is I can't soundwhore like I could with my mixamp so I'm at a disadvantage now vs others that can hear me across the map. I'd like to be able to hear them more otherwise I'll have to return it
I haven’t tried fiddling with the EQ cause I have no idea what I’m doing. I did have custom EQ’s loaded into the Mixamp TR which is probably why footsteps were so loud - I could pinpoint enemies from far away but they have to be pretty close now unless I’m not moving/making any noise.
Has anyone made any tweaks to get the footstep sounds louder in Modern Warfare and can share their settings?
Try turning crystalizer on, setting a flat EQ, and set surround to 100. If crystalizer does not do it for you try a slight boost between 2k and 8k in EQ. But always keep surround at max.
I have never tried the A40's as headphones but I imagine even "cheap" good cans would be an improvement in staging and imaging. E.g. PC37X, HE-4XX, HD598. The AD700X is usually well regarded in the FPS positional audio department, maybe also try that again with the G6 vs. the mixamp.
