Deaj
It looks like they might be 3.5mm TS or TRS connectors.
This is what I'd prefer to use but I haven't found a quality, robust female connector that may be removed from the cup and replaced should it fail.
And on that note does anyone know of a quality, robust female 2.5mm or 3.5mm connector that may be installed securely in wood cups, and removed from the cup and replaced should if fail. I would MUCH prefer to use a phono type connector.
