Wayne, is that a different leather headband on those final pics or is it just the lighting/angle?
Can you elaborate a bit on your impressions on the Grado stock headband with a j$/turbulent labs leather upgrade vs. the Sony one if you can?
Yes. I've really grown to become a fan of the Sony 7506 head band. It is constructed quite well and has some great methods for applying adjustments. The side gimbals allow for rotation on two axis points. This ensures that the headphone cups / ear pads allow for an excellent adaption for one's head and ear angles. There are also adjustments for height to provide options to fit heads of different sizes. The Sony band has metal sliders that go up into the headband to facilitate this. The metal sliders stay exactly as you set them until you decide to move them again. This is in contrast to the Grado gimbals which can get a bit loose over time and with use. The Sony headband is engineered quite well and under the plastic covering the mechanism for sliding, they have a ball bearing which is backed up by a spring which works towards keeping the headband adjustment in place once set. However, if you want to adjust the band, the task is quite easily performed and the ball bearing permits a smooth movement during this process.
The only small drawback of the Sony headband is the width of the plastic "peg" opening vs. wooden cup diameter. With this pair of cups, the diameter was cut slightly larger than the Grado spec, and allowed the headband pegs to fit into the cup holes, once they were bored slightly larger with a drill. On wooden cups that are cut more towards the true Grado sizing spec, the gimbal spacing will be about 3/8" larger than the diameter of the wooden cups. However, this is quite easily remedied. If one has a heat gun or a hair dryer, the inside (head side) can be slowly heated and moved slightly to narrow that gap. This process should be done slowly and might require 3 or 4 heating cycles to complete the task. Again, note that this should be done on the inside (head side) of the gimbal as plastic can sometimes discolor a bit when heat is applied. This ensures that if some discoloring happens, it will be concealed from normal view.
Now, the question of the Sony band vs. the Grado band and using a leather headband upgrade. In most cases, the builder or modifier would have to locate a Grado headband and gimbals for use. This could mean a cost of $30 to $40 to acquire the parts. Even if one has a "donor" pair of Grado headphones, something would still need to be done with the cups, drivers and cable if you're going to do a Magnum build. I would instead suggest that the person sell the pair of Grados or donate to a friend or family member. This would ensure that another pair of Grado headphones remain in service. Finally, while I do love the look of a nice, custom leather headband cover, it also adds additional cost. Thus, if you were to spend $40 to acquire a Grado head band and gimbals for $30, you would still have to drop another $45 or so for the leather band. This places the cost at $75.00. For the faithful Grado purists, this method might be one that suits them best - cost aside. The Sony option can be acquired for about $30, including shipping (if you reside in the U.S.), and does have a fair amount of padding already built into the head band. This allows one to be comfortable with their headphones without laying out too much additional cash for the head band upgrade options.
I have seen the use of another Sony headband from a different model of headbands. But, the other one being utilized doesn't look nearly as comfortable as the 7506 band, which is slightly larger and provides the padding option. One also has to keep in mind, there is lettering on the top of the Sony 7506 head band which says "STUDIO MONITOR". In the two that I've acquired for my build processes, I've found that using a small amount of acetone on a paper towel allows you to remove the silver lettering, which just appears to be paint. In doing this, one should work slowly, and not utilize too much acetone. Remove the letters slowly by wiping or rubbing - but not with a lot of force or too excessive. The acetone while being able to remove the lettering can also work against the pleather too, and you don't want that to become an issue. Paying attention to the work and working slowly will ensure your complete the task successfully.
Very nicely done
there's nothing like the anticipation while you wait for parts for a build, and the feeling once its done and successful.
When they first came out people seemed to either love or hate the new Magnum drivers. I personally loved my first build with them, and can't wait to finish my second. To my ears, after being exposed to the SR line from the SR60i up to the SR325is (with the exception of the SR125i...need to have a go at them too), they felt superior to anything I had experienced before.
No doubt. The anticipation can be felt a few times. Having the luxury of aligning the times for the wooden cups and the driver shipments can be challenging. This could be minimized by ordering the drivers and cups from Turbulent Labs. To me, though, I want to be somewhat unique in what I have the time to work on. With all the Grado modifications or Magnum builds, I've never done the same build twice as I've liked each one to be completely unique. I've been fortunate enough to have had cups from about 6 different species of wood and in each case, I've refinished the cups that were finished to start with so that the modification could be unique to what I was doing vs. another individual. In the end, this does take more time. However, the challenge of making it unique - yet tasteful is also half the fun for me. But, I can also accept that not everyone has the access and the materials to handle such a task at their disposal, so the ability to be unique can be somewhat limited, too.
With this aside, the Magnum build components were all in various phases of procurement when the offer of a Grado PS-500 came along. The PS-500 was a model that I had the option to acquire also had the G-cush pads so I could have a headphone that would perform a bit further up the Grado chain, too. My original intent was to have my RS1i and the Magnum build as my only main headphones. But, with the PS-500 in the picture, I really won't have a use for the Magnum build. I don't feel that the Magnum is really below these other models in any way as it really does provide an excellent return with respect to sound quality and product quality for the price paid. I personally feel that the Magnum is worthy of being on the same shelf as the RS1i and the PS-500 as the signature in my view, is pretty high quality, but a slight bit different from an offering directly from Grado. Since I can't use all of these headphones, I will be listing the Magnum build at $299 + shipping fees on the forum before the weekend is over.
