Looking to buy some speakers soon. Can anyone recommend a speaker that would appeal to someone who likes the Grado sound?
Yes I can.
My speaker of choice actually led me to try Grado's. Ohm Acoustics is also manufactured in Brooklyn. They are built by hand, and each speaker is tuned by ear, pretty much just like Grado.
The thing that makes them special is the Omni-directional design using a form of Walsh driver. It's an inverted driver than reproduces the entire frequency range up to 8000 Hz, where a super tweeter takes over. The soundstage is MASSIC, and the imaging is scary in its precision. They are not well-known, but they have a dedicated following that goes back to the 70's.
More info can be found here : http://www.ohmspeaker.com/speakers/
I personally have the Ohm Micro Walsh Talls, and I used to own a pair of Ohm F's. I doubt that I will ever need to buy another speaker brand- they are simply amazing.
