Deleted due to my mistake in which foam I was using.
There are some amps that make them brighter. Check with a different source.Anyone have any tips for someone with a set of Grado sr225e cans that are just a bit too bright?
EDIT: The Beautiful Audio Pads I'm using with the 'Open cell foam' inserts just to be clear.
I don't have the 'Reticulated foam' inserts. If ordering these pads new, they come with both foam inserts.
First of all, I made a mistake in this post saying I'm using the "Open cell foam"...I'm actually using the "Reticulated foam".I tried the reticulated foam again recently. I found that it hurt the sound as it pushed the cups further from my ears. After less than 5 minutes I put the white foam back in.
Shane D
In this video BA is showing the "Open cell foam" (white foam pads) which are stated to be "on the hard side".
The "Reticulated foam" (black netting) is not shown, but is stateing to be "on the soft side", this is what I'm using.
I'd think it would be the other way around, and the "Open cell foam" would be harder than the "Reticulated foam" but that's not what they're stating as seen below.
I'm finding the "Reticulated foam" to be ultra soft because it's a netting, so even though I don't have the "Open cell foam" to compare, I just can't imagine it being softer than the netting used in the "reticulated foam". Am I missing something something here?
EDIT: I also don't see how the "Reticulated foam" could push the drivers further from your ears being they're so soft?
Interesting.
Thanks for the verification on which is actually softer. As I mentioned, I would've definitely thought the reticulated foam would've been softer than the open cell foam. I'm going to email BA and see if I can just purchase the open cell foam and try it out.
Hi guys,I wish that white foam was just a Little bit more dense. It is SUPER comfortable, but my pads are really compressed.
Hi guys,
Was just intrigues to do a little experimentation with the foams in the BA pads on my GH2s. Been using the white stuff for quite a while, as Shane says very comfortable indeed. However, I started to feel the wer "collapsing" i.e. sitting tighter to my ears, and to my ears were absorbing sound in a different way. A week ago I tried to go back to the original L-cush and liked the sound a little better (despite the decline in comfort). Now I have switched to the "reticular" aka black foam on the BAs. Guess what, I am back in business. Despite they seem a little harder, they keep the distance to my ears and this - too me - right now - gives a "better" and maybe more clear and distinct sound.... We'll see if it wears off
I'll let you know. "Burn in" has now got a new dimensionI would be really curious to see if they start to compress on you as the white ones did. And if so, how much.
Here is a comparison of the GH-1, the Grado Bushmills X, and the RS1i that I did here: https://www.head-fi.org/threads/grado-fan-club.530965/post-12056836 Higher numbers are better.New to Grado's guys. I have GH-1 use it a lot and like it, would RS1i compliment these or too close to bother?
Can anyone explain difference here, and please, try not to over exaggerate (I know it's easy to do this is a fun/exciting hobby).
I use an amp, and used to listen to older rock/pop electric guitar based music but have moved to more modern rock/pop/post-punk even a touch of drum machines/keyboards lately. Thanks!
