Grado Fan Club!
- Thread starter Vikingatheart
- Tags
- 1000hours burn-in minimum 1000hours hearing damage minimum dynamat grado grado hf3 grado-gs1000 grado-head-fi-series-hf-2-headphones grado-igrado-black grado-professional-series-ps500-headphones grado-rs1i-reference-series-headphones grado-sr-80 grado-sr125i-headphones grado-sr225i-headphones grado-sr325is-headphones grado-sr80i-headphones grado-statement-series-gs1000i-headphones nhoord nhoord red v2
CH23
- Nov 24, 2012
Finished painting/assembling my aluminum rodblocks on my PS1K in Flat Black then Semi-Gloss Finish.
would be nice if a seller of these made them with a L and R CNC'd onto them (or a cutout to stick them from the original rodblocks)
they look nice though!
ruhenheiM
- Dec 27, 2010
So what are the differences between the 60,80,125,225 and 325?
i think @ruthieandjohn could answer this more properly since he actually have all those models. i haven't tried all of them but more or less the differences are in clarity,bass and added warmth. all of them still sharing the same sound signature of grado. which compare to other brands the grado sound more airy, tight bass also quite good speed, the mid is forward very intimate and the treble have those raw sound.
each model more or less are incremental improvement of the lesser models in clarity. the added warmth and bass sometimes very audible sometimes subtle depend on which models being compare
basically the simple explanation i could give is this
60= this is the basic grado sound. airy,tight bass,forward mid,little bit warm,also bright headphone
80=pretty much the same as 60 but this one have tighter bass also the bass go deeper. the sr60 have more bass slam though but compare to 80,sr60 bass sound bloated
125=haven't heard this but this is pretty much like 60 but better in technicality
225=haven't heard this but this is supposed to be sharing the base sound of the reference series. which means,airy,very intimate mid and have depth sound stage, clarity is good and have that added warmth
335=this is the most detailed grado in prestige series, in term of technicality this is just better compare to other prestige model and musicality this is just like other grado headphone,very musical but this headphone have those treble boost. so it might not suit everyone taste
ruhenheiM
- Dec 27, 2010
is it supposed to be matte finish? or that's just lightning effect? if you could put some wood plate as L and R label that could make the headphone look so awesome
ruthieandjohn
Stumbling towards enlightenment
(Formerly known as kayandjohn.)
Take a look at the link in my signature labeled "Huge Comparison of (Nearly) All Grados" for rankings of the Prestige Series (and others).
Just came across this singer/guitarist. Bought her new album "Where I Belong" it is terrific
DivaFonda
In a nutshell, price
Is that entirely true though? People have said there are indeed differences between each model and the website does too. Driver matching and cable differences that might influence sound. Not to mention the build of the 325e is premium over the others. I have long been tempted to get the 325e even though I'm satisfied with the 80e.
Thank you.would be nice if a seller of these made them with a L and R CNC'd onto them (or a cutout to stick them from the original rodblocks)
I just took a look at the L/R indicators on the Grado rodblocks, and never realized that their separate pieces that are inserted. It look as if it would be kind of hard to remove them without damaging them, though, but great idea!
No, their painted in Flat Black, then painted with a Semi-Clear coat.is it supposed to be matte finish? or that's just lightning effect? if you could put some wood plate as L and R label that could make the headphone look so awesome
What do they appear to look like to you? I'm asking because the Flat Black I used may have had the wrong cap on it and it may actually be a Flat Wrinkle Black, do you see that?
Then get the 325e, otherwise you'll always be wondering if you should have. I've never heard the (e) but I own the (is) for 4+yrs and they're still my desktop headphones which I love and alway will! I also had the 80i and they were awesome as well, but once I bought the 325is I didn't listen to the 80 much, so I gave them to a friend to enjoy and haven't missed them due to owning the 325is."I have long been tempted to get the 325e even though I'm satisfied with the 80e."
DivaFonda
Thank you for the advice! I'm probably going to have to wait until 2018 unfortunately. Splurged on another set. It is not a Grado.
It's OK to mention you purchased another brand of headphone on this thread, we're all very easy going here, so what did you get?Thank you for the advice! I'm probably going to have to wait until 2018 unfortunately. Splurged on another set. It is not a Grado.
ruhenheiM
- Dec 27, 2010
i have no idea about the color description. mmm not sure how to describe it.but it looks like they have a texture.the color looks like chord mojo to me.and since it also looks like a little bit texture,i assume the feel won't be a smooth surface when being touch
DivaFonda
The Focal Elear sale drew me in because I never owned true high end before. Not even close to the Grado sound but good in their own right. Still holding onto my 80e though. I like the true open-back sound. Elear is supposed to be open but seems more like a semi-open to me.
ruhenheiM
- Dec 27, 2010
lol. that's the most distinctive difference for sure and i think it was also a joke. but on cosmetic side. yes it is big difference.the cable,the pad,the headband since the sr325 is basically on premium side, it share the same build quality like higher model. for the sound. i listened sr60,sr80 and sr325i . it is big difference, but then again it was sr325i, compare to other grado models, that headphone is very different kind of beast. although, i'm not gonna lie, other prestige series especially modded one compare to higher model, on first listening, you're going to wonder why would you want to buy higher model but after a while, the differences are thereIs that entirely true though? People have said there are indeed differences between each model and the website does too. Driver matching and cable differences that might influence sound. Not to mention the build of the 325e is premium over the others. I have long been tempted to get the 325e even though I'm satisfied with the 80e.
Total: 49 (members: 4, guests: 45)
