i too, silent when its supposed to be, no clipping, distortion , and the highest i've gone with volume is 12:00, no strain at all
Yep, I can't imagine the amp clipping at anywhere near the 12 o'clock position unless the issue is source-side. Clipping occurs when the signal hits the voltage rails and can't go any higher. I don't know what the output voltage rails are of the amp(s) in question.
And if it really is distorting at that volume position, I'd again question the source or something else upstream.
Unless you have something funny going on upstream, your amp should not distort or clip unless the volume pot is all the way up... now, if you are just nervous about it clipping/distorting, that's an issue between your ears
Nooooooo!!!!!!
It depends entirely on the topology and the gain structure of the amp. Just like you, a MAJORITY of the amps I've used, generally class AB with op amps (solid state) tend to act this way. Class A, certainly not, and class D varies depending on gain and output stage.
If there is no noise or other bad sounds, and you need to crank to 3 or 4:00, there is no problem. It's just weird...
No, I've never had ant issues with the amp clipping/distorting in any way at all.
All I'm saying is that between 1-2 o'clock the PS's start too really shine for me. I'm just worried I'm pushing the amp a bit too much at 1-2 o'clock point, but never had any issues. When I come from 1-2 o'clock back down too 12 0'clock the volume difference is much, much lower, thats all…this is why I felt the amp was peaking at this point, and wouldn't push it any further nor did I have too…but no clipping/distortion at all. Also depends on the Cd also, so I was just looking for a little more increase in volume before 1-2 o'clock because I was under the impression that ANY amp at this volume position (1-2 o'clock) is at its maximum, but bbopcans lead me too a sight which explains volume position, and how it is irrelevant to the output of the amp, because all amps are different, and it runs way deeper than just the volume position, so I was incorrect.
