TheChosen0ne
- Dec 29, 2011
650s are like normally $500 right? Seems like a good deal lol
I usually like my stuff new but refurbished is basically like new right?
You'll want to check the IEM/portable forums. Almost no full sized audiophile headphones will have a remote + mic built into the cable since it degrades sound quality.
Nope!
As a previous poster mentioned, not a whole lot of cans have the mic. However, if you still like IEMs, a lot of those do have the remote/mic combo, so maybe look there. The only one I can think of in your price range that fits your reqs is the Klipsch Image Ones, which aren't particularly good, as the bass is a bit overpowering.
Getting new headphones in the 100 to 200 dollar price range, preferably around 150 dollars. My choices boiled down to The sr225, sr125, Hd558, Srh840, and the m50.
I'm just having a hard time deciding which one to get as my first REAL set of headphones. I'm open to any advice. I mainly listen to classic, grunge, and alternative rock. But I also listen to classical music too. Another thing is that I like bass, but not overwhelmingly so. I will be pairing my headphones with my cowon j3 that I just ordered.
Im looking for something different and maybe even upgrade to better, Im still gonna save these cans they are awesome, but they clamp to my head really hard and it starts to hurt after couple of hours. Also want to try different brand.
Should I get new HD600s for $316 or refurbished HD650s for $309? Amazon had this fulfillment by amazon thingy and the company that is selling it is Pinnacle Deals.
sennheiser hd215!! what do u guys think about it?? i badly want it!! thanks alot guys!!
Hello all!
I'm looking for headphones good for (basic) mixing, and listening purposes. I will mainly use them to make hiphop and dance music.
Preferably non-amped .. budget around 150. I'll most likely plug them into my Yamaha R300 speakers amp as it is hooked up to my computer (for old AR-4X speakers).
Any suggestions ? It needs good sound for hiphop, dance but not anything too much since I'd like to mix with it as well!
Hope you can help.
Im in the market for a new pair of headphones, and want to buy a pair of Sennheiser headphones, my last pair ( which are now broken) where sennheisers and they were some of the best headphones I've ever had.
Im looking at buying the HD 429s and a FiiO E5 amp.
I will be lisining to my music ( classic rock and heavy metal) at a loud volume in a loud enviorment ( most of the time) my budget is 100$ ( plus tax and shiping)
I just want to know if this is a good setup for me, or if their any better headphones and amps in my price range. ( preferabaly sennheiser but im open to other brands.)
thanks in advanced, and sorry for any spelling errors, I cant seem to find the spell check button.
heres the links for the headphones ( just google FiiO E5 my computer doesent want to do the link) :
http://www.sennheiserusa.com/over-ear-headphones-portables-hd-429-mid-size_504763
EDIT: I will be listening to the music off my Ipod touch and computer if it helps to know
I am looking for a pair of headphones around $50 that have good accurate, clean, and precise bass. I am tired of the muddy sounding bass you get from the under $50 headphones. I have read about the panasonic HTF600 and they seem like they are popular for their bass. are there any other suggestion? For reference i listen to a lot of music with double kicks and i definitely want to hear an accurate reproduction of all the bass runs that are in music, but i also don't want to sacrifice the mids and highs any more than i have to get that bass, but i also usually appreciate the headphones that are fun to listen to, though i like my grado SR80's but they just seem like they need more power to drive like they would really benefit from a headphone amp which i don't have.thanks for any suggestions.
Headphone cables with a built-in mic and remote deteriorates the sound quality? Is this true? Is so, is it a noticeable difference (like black and white) or is it a very slight difference?
Hello! I'm new here.
I am looking for a new pair of headphones for home use.Mostly music (rock, metal, industrial, instrumental, progressive etc.) and gaming. My budget is $300. Most people recommends Sennheiser HD558. I was looking Sennheiser PC 350 and 360 because they have mics. So, mic would be preferable but not necessary.
Are HD558 good enough? Does mic disrupts sound quality? Do I need amp?
Please help!
HTF-600 accurate? No. They can be fun, though. Grab the Monoprice MEP-839s for $25. Best HPs for <$50, IMO. Some companies are selling them for $100 and all they do is add some red or gold paint.
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10823&cs_id=1082302&p_id=8323&seq=1&format=2
