Random Guy
- Jan 27, 2013
I found after about 3-4 hours use of on-ear headphones are not comfort, so i would like over-ear so i can listen to them for like 8 hours. I tried the momentum but found there a bit bass heavy. Okay thanks for the suggestions, i read a lot of views on it and found they are very good if they fit properly but usually they dont. Have you tried any of the others on the list that i can narrow down?
Does anyone else use any of those headphones? how good is the isolation, is it good enough for buses?
I would say try on-ear headphones like DT1350, Momentum, Amperior, and more. Drop K550 from the list too(they don't isolate much). Open back on ear like SR-80 will not, but others that I suggested like DT1350 and Amperior isolates almost as much as an IEM, which is very good.
