daleb
- Mar 21, 2013
Hey Hey Hey, the 280s can be really brought out with my EQ settings In fact, vocals can give me chills for some songs with them now. Guitars still sound lack luster, though. I have a 3 db boost between 1.8 khz and 5 khz (then it slops back down and ends at 20 khz), and a dip of 4 db between 220 and 440 hz, and a dip of 2 db between 440 and 622 hz, using Foobar. The midbass and low mids are very muddy on these, sadly. The Q701s are nothing like that, right? It looks like that section is way stronger then I would like. If you look at the 2 charts in comparison, the Q701s average about 4 db more in the treble, so slightly brighter then my 280s setting? But I'm pretty sure it has a lot more to do then just the frequency response for why its considered bright. How does it handle vocals compared to the 598s?
edit: Also, would the Q701s work with the E11? That's a little cheaper then the E10s.
The Q701 has a very nice and detailed treble that is somewhat bright, but definitely not fatiguing to my ears. Coming from something like the 280 which is particularly dark and awful with the treble (and everywhere else), it's going to be an adjustment. It will be less so or an adjustment with the 598, but it's still a night and day difference. Both can will definitely be less forgiving on bad quality audio, moreso with the Q701. If you are really really worried about it, the 598 is the safer bet.
