Some more thoughts on the LE & regular Pro. (Sorry for the spam )
As I said before, the LE isn't a dry or bass shy HP by any means. If you enjoy the Pros bass, you'll like this one too.
I actually made some measurements with a DB meter. Althought it's an homologated DB meter, they can't be taken as proper measurements, but sadly I don't have a measurement rig.
I found that from 50 to 100hz, the LE had 1/2 db of bass above the normal pros. From 100 to 150hz they were even, and from 150/200, the LE was 1db below most of the time.
This could explain the feeling of a slightly dryer bass. You can call It a "more refined" bass if you want.
Both HPs slam like mofos anyways.
Still making comparisons but my intention right now is keeping the LE. It gives me the same sound signature than the regular one but with a hair more clarity and spaciousness, better comfort and I can always use the G pads to give It an extra bass boost.
That said, I think that a used regular pro is the best value. Id recommend the LE to people whose endgame are the Pros and prefer the black finish or want something exclusive.
